Shifter Play.
  • E30_Pare
    • 7801
    Shifter Play.
    Ok so basically I have lots of play in my shifter. Just replaced all the bushings with new oem ones not to long ago. My shifter is not stiff at all and moves extremely easily in neutral and while in gear side to side. I want to tighten up my shifter, but don't have any ideas where to start or check for that matter.
    *Note: Not a short shifter. I am using the stock lever.
    DREWLIENTE
    1$ PShops PM me
  • E30SPDFRK
    • 5713
    What style shifter support do you have?
    Byron
    Leichtbau
    • E30_Pare
      • 7801
      which part are you talking about?
      DREWLIENTE
      1$ PShops PM me
      • E30SPDFRK
        • 5713
        I was asking if you had #5 on the second pic type support or the other type. There should be an allen-head bolt on the back side that you can tighten up. This can work its way loose over time.
        If that is fine, what shape is your shifter ball in?
        Byron
        Leichtbau
        • E30_Pare
          • 7801
          Ah ok. I just took a look at my shifter ball and it looks to be in good condition still. I'll take a look at the support in the morning.
          DREWLIENTE
          1$ PShops PM me
          • Jean
            • 18228
            Replace parts #1 and #16 at the minimum, #4 does wear out as well and if your shifter is original it might have lots of play in it on it's own as is it's not 1 piece.
            • Kingb
              • 928
              I ahve a 90 325i and I bought an ebay SS and teh shifter rebuild kit from pelican for like $80 and mine is still sloppy. I replaced everything that came with the kit except for the plastic cups since I had a new shifter and #14 I couldn't get that thing in there lined up. It feels like I am in Nuetral when it is in gear. What gives?
              Originally posted by Nicademus
              My car beats off to that car. :bow:
              • Griffin
                • Dec 2008
                • 68
                I've got the same issue on my 84 318i. lots more play pulling the shifter left than right, so reverse is a chore to get into. I'm ordering the rebuild kit from pelican, but hopefully I don't have the same issues as Kingb when I'm done!
                Neal Mulcahy - 84 318i
                LRRS/CCS #427 ECK-Racing 2009
                Pine Motorparts/PBE Specialists | Phoenix Graphics | Woodcraft | Moon Performance | Motorcycles of Manchester | BostonMoto-Pirelli
                • E30_Pare
                  • 7801
                  I'm going to order the rebuild kit from pelican soon. Let me know how it works out for you.
                  DREWLIENTE
                  1$ PShops PM me
                  • ieatpeople
                    • Mar 2008
                    • 883
                    i have the same problem with my 88 528e, keep me posted on that shifter rebuild kit.
                    Originally posted by BillBrasky
                    That's like Vlad challenging Chip Foose to a car painting contest.
                    Originally posted by acolella76
                    i'm pretty sure 'Phillis' is short for syphilis
                    2007 CVPI, stock and slow
                    1994 tercel, 5efhe swap, i/h/e
                    1984 t-type, 5.3/th350 swap in progress
                    My newest addition:
                    Rebecca Arlene, born 4/19/2013
                    • Rlp815
                      • Jan 2010
                      • 1
                      I have this same problem. New short shift kit, but the shifter moves a couple inches side to side while in gear. Whats the fix?
                      Bob
                      • Jean
                        • 18228
                        This isn't really rocket science guys. Look at EVERY platic/wear item and replace it (this includes the shifter ITSELF). Done.
