TheEuroDepot 5 speed swap
  • stinkydriverx
    • Jan 2008
    • 501
    Does anyone think its worth the 1500 to have every thing needed for a 5-speed swap?
    All wearable parts such as the clutch kit, hydraulics, mounts, etc. are new.
    All non-wearable parts such as the transmission, driveshaft, pedals, and cluster (select models), are used or refurbished.
    heres the link to the site=
    Turbo m30 drift car build.
    500whp or bust.
    http://www.r3vlimited.com/board/showthread.php?t=256525
  • SpecM
    • Oct 2005
    • 4531
    that's not such a bad deal, considering all the new parts
    1989 cirrisblau-metallic 325i
    • PУCCKAЯ_e30ka
      • Jan 2006
      • 1226
      I'm over that on mine... but whatever I could get new/best shape, I got.
        While it can (usually) be done for less, the EuroDepo kit is good value for the money. They do provide new parts where appropriate (master & slave tranny mounts, clutch, etc) and you will get a set of parts that is simply a bolt-in.
        • germancarsonly
          • Mar 2008
          • 1350
          I'm converting my 325is to a Z-F trans and can sell you most of the parts that you will get from the Euro Deopt for 1/2 that price. You can probably find a good deal locally on the things that wear out like the clutch & presure plate, trans mounts, shift linkage bushings, and the few other little parts. I'm not a retail store and only have the used parts.
          You will also save some money on the shipping as I'm only 500 miles away from you.
          If you are interested send me an e-mail and I will work up a detailed list for you. germancarsonly@gmail.com
