On my S52 swap using the Getrag 250 trans, the Z3 shifter seems like it is sticking up way higher than I remember the stock shifter. I know the carrier holder at the rear positions the carrier/shifter and I wonder if it can be lowered to change the position of the lever...does the holder have to be attached using the 2 prongs on the underside of the tunnel or can I turn it upside down to get a better position?
Just thought of something else...I'm using the 320i trans mounts, are those taller than the stock mounts? If they are then that would explain why the shifter is higher...
