Hey guys, is there a good write up for this procedure? I've searched and can't really find a hop write up. I really need to get this done and do not want to spend 300 paying someone to do it. Help me out.thanks
					Clutch master cylinder help??
 bleed your clutch slave (to the driver side under the transmission) you can do this buy hooking some tubing up to the small bleeder valve and inserting it in a container and open the bleeder valve and push and then pull the clutch back and forth until no more fluid comes out. Then disconnect the clutch pedal from the cylinder. Then what you are going to do is get to the 2 10mm bolts that hold it to the pedal bracket and take those off after that you should be able to pull it up and then disconnect the clip off the hose that looks like it has some material over it(mine was blue) and it is the tube that comes from the reservoir and then disconnect the hydraulic tubing that goes to the slave cylinder. The installation is the opposite of removal.1991 318is Track Car
 1986 190e Cosworth
