That pesky bitch clip on the getrags....
  • Erick
    Official R3V Drifter
    • 11169
    Does anyone have more info on that? I have a new tranny that I'm going to put in and I can't seem to find anything with the search function.
    Thanks,
    Erick
    ..::Support FullOpp::..
    FullOpp Stickers for sale!
    Feedback Thread
  • scott_is
    • Aug 2007
    • 310
    you mean the shifter one?
    Scott
    • Erick
      • 11169
      Yeah, that gives the slop on the shifter. How does one go about removing that?
      Feedback Thread
      • gazellebeigem3
        • Jun 2005
        • 3712
        yeah... if you're talking about the shifter clip, its only a little bit difficult if its never been out of the car.
        • Erick
          • 11169
          the circle clip around the selector on the transmission?
          Feedback Thread
          • SamE30e
            • Sep 2007
            • 4319
            It's on the front of the shift carrier, attached to the top of the tranny. It's a pin that goes through and has a clip. Check RealOEM.
            1985 325e 2.8 Turbo VEMS
            • E30SPDFRK
              • 5716
              Use a small pocket screwdriver. Reach up over the top and aim the screwdriver backwards and pry the tittle tab out enough to start rotating it upwards.
              It got that name for a reason: I had my car on a lift while I did it and it still sucked. Good luck!
              Edit: I see the transmission is out of the car. Change it now! it will be so much easier.
              Byron
              Leichtbau
              • gazellebeigem3
                • Jun 2005
                • 3712
                Im confused about what you mean so:
                http://www.realoem.com/bmw/showparts...27&hg=25&fg=05
                best way i have found is to drop the trans down a bit, get a stubby screwdriver in between the transmission and the u-shaped part and pull up/toward the back of the car
                #18 & 19
                Has a metal band around it that you pop off and use a pick to take the pin out. piece of cake.
                screwdriver
                • Erick
                  • 11169
                  18 & 19?
                  - Erick
                  Feedback Thread
                  • Erick
                    • 11169
                    #18 & 19
                    screwdriver
                    Wait, that gives slop? I have a poly bushing in there and I still have some slop. I remember people like Jordan saying that after whatever they did to this clip, they had less than a dime's length of side to side shifter play.
                    Feedback Thread
                    • E30SPDFRK
                      • 5716
                      #3 is the bitch clip.
                      18 and 19 aren't too bad, just use a small pick to pull the sheath/clip back and push the pin out with a screwdriver.
                      Byron
                      Leichtbau
                      • SamE30e
                        • Sep 2007
                        • 4319
                        What is a big contributor to slop is #4. Or at least in my case it was.
                        • E30SPDFRK
                          • 5716
                          #14 is what you are looking for then. Just buy a new one.
                          Byron
                          Leichtbau
                          • gazellebeigem3
                            • Jun 2005
                            • 3712
                            yes,this can get worn out. and may i say that this thread has been quite confusing
                            • Erick
                              • 11169
                              Agreed, but I believe #14 is the cause of slop. I've always felt massive slop on it on all transmissions I've seen. The #3 I've done many times, and like I said, it's on polyurethane right now. Still some slop left over.
                              - Erick
                              Feedback Thread
