Hey guys,
Weird question, is there an adjustment for the clutch? I know on some cars by the clutch pedal you can adjust a the cylinder a bit, is this the case on the e30's?
Reason I ask if, I have my m50 swap, G240 tranny and single mass flywheel with euro TOB but it's just not enough to fully disengage the clutch, if the clutch is pressed in I can turn the output shaft by hand, but there is some resistance.
Thanks
Sam
Thanks
Sam
