I have a stock single mass flywheel for my Getrag 260 swap into my 1988 325is. I found a performance Engine Machine shop that will lighten and balance my flywheel for $150. They are very well respected and skilled, I am not worried about that. My question is will I gain much over a stock flywheel, will I need to be aware of creating any problems in reliability? In general more guidance is appreciated. My flywheel 1985 325e, I the matching trans, clutch, pressure plate, etc..
Flywheel Wieght Reduction?
Most guys shave it down to about 12 lbs.
As long as the shop knows what they're doing and don't tank off too much material, it'll be fine.
ErikComment
Not what I'm meaning. 8.5 lbs is minimum for the engine is what I hear, but like I said I don't know why maybe the crank will break or something.Comment
^^Yeah most guys take the stock flywheel down to about 12 lbs., which was standard for the early 320/323i flywheels. The 12 lb. flywheel will give you no problems with reliability and such.
The biggest gain I've seen with all of my light flywheels is the deceleration when downshifting. They also rev a bit more freely, of course, than the stock 17-28 lb. flywheels.
$150 for that service sounds about right. That's a little bit more than you might pay for a 320i/323i flywheel if you can find one, but it saves you the trouble of having to look.Comment
a 320i flywheel will fit the getrag 260? how much does it weight in total? Im asking cuz I have a 320i sitting at my shop as we speak.
TaylorComment
Yeah it'll fit just fine. I think you might need to check into the clutch/pp/to bearing combo (you should need all 320i/323i components). It's the same flywheel just turned down because the 320i/323i M20's had a heavy balancer on the front of the motor instead of just having the heavy flywheel behind it.
Weighs 12.75 lbs. according to the UPS postal scales at Mitch M's shop.
This is, of course, M20 E30 320i/323i cars.Comment
Worth it?
Kind of depends on what you are after in performance gains and what you are willing to sacrifice / trade for it.
A lighter flywheel will spin up faster but it will also spin down faster (not a desirable trait for long track or street use).
A good weight is right about 13lbs for an M20B25 (16lbs for an M42*) for all around performance and drive-ability.
*4 cylinder engines need the weight to carry the power pulses through.I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".Comment
I agree.
Swapping from a dual mass flywheel in my eta to a single mass was a night and day difference. That was just from a 28 lb. to a 21 lb flywheel (weighed all of the E30 flywheels one day).
My 318is went from a 28 lb. dual mass to an 8 lb. single mass, and my S52 eta went from a 28 lb. to a 11 lb. flywheel. It's one of the best modifications you can do to a car, in my opinion of course.
Like I said, my favorite improvement of the light flywheel over the heavy stock part is the engine braking. It really helps not to have all of that reciprocating mass. Of course, theoretically more reciprocating mass would put less effort on the motor when you are cruising at constant speed, but when you are actually driving the thing how it is meant to be driven that isnt something you should concern yourself with.Comment
Balancer on auto M20B25?
Thanks
DennisComment
Improvements I want
Worth it?
I believe the fast spin up and additional engine braking is what i want for my driving in the mountains of Eastern mountains of Kentucky and Tennessee.Comment
rThor432, are you experiencing any gear lash/rattle/noise due to your 8 lb. single mass flywheel on the m42?Originally posted by nervousminiBreak My Wallet
Bring My Wallet
Bring Money With
and the M cars are a multiplier
regular repair Money * 3 = M3
regular repair Money * 5 = M5
regular repair Money * 6 = M6Comment
