Little, yellow, missing...
    I installed a short shifter from Understeer.com over the weekend. That and the UUC clutch stop. WOW! Amazing difference in how the car feels.
    Here's the question: when connecting the gear selector rod to the new shifter there wasn't room for the little yellow nylon washer in between the gear selector rod and the shifter. If I had the nylon washer in there there was not sufficient width on the gear selector rod to get the circlip mounted on the other side. It seems as if the shifter base is just a little wider than the stock one I removed. I went ahead with the install (minus the yellow nylon washer) and it shifts great. Any reason to be concerned? It seems like a minor deal but also there is a reason those nylon washers exist right?
    1987 325is
    --- used to haves ---
    1988 325is
    1999 540i/6/Sport
    1989 325iX
    1998 M3
    I believe they exist to cut down on on the shifter movement from side to side when in gear but I am sure they also prevent wear from the shifter rubbing against the circlip but I am not sure on this
    1991 318is Track Car
    1986 190e Cosworth
      youll be fine. they are there only to be a surface other than metal for the shifter and circlip to rub against.
      i didnt put them in when i installed mine and i havent had a problem for over 2 years.
      Taylor
        Some shifters have those yellow shims integrated into them. The gray plastic bushing in the base of the shifter sticks out a bit on some shifters, and the yellow spacers arent required to remove slop from the assembly.
          That is pretty much exactly how my replacement shifter looks. Thanks for the answers, I'll stop worrying about it now! :)
          1987 325is
          1988 325is
          1999 540i/6/Sport
          1989 325iX
          1998 M3
