Gruppe,
I am chasing a nagging, continuing driveline vibration in my race car.
I have the driveshaft out being checked for balance to eliminate that aspect but I am about 99% sure I am going to find the problem in the driveline angles and not in the driveshaft itself.
I am looking for a measuring point on our Med Case Diff that is parallel to the pinion. Does anyone know for sure a point on the bottom of a Med Case Diff that equates to parallel with the pinion?
There are 2 small machined pads just under the pinion end of the diff, then there is a 3rd one somewhere around the middle of the case on the bottom, there are also 2 threaded machined pads towards the rear of the diff that are unused on the E30 chassis.
All of them yield different angle readings.
The ideal method would be to measure from a flat side of the yoke, but that is encased in the rear subframe. Cannot get at it.
My race car has a Tremec transmission and I am using a one piece driveshaft with a slip yoke on the front.
We / I have mitigated a-lot of the initial vibrations from when this project first started but there is one nagging vibration remaining that starts blooming around 5500 driveshaft RPM and really develops at 6000 driveshaft RPM that I want to get out and I am sure its in refining the angles.
In order to do that I need a reliable point to measure from that is parallel to the pinion to get the relationship to the transmission output angle then I can adjust by shimming diff and / or trans to get it correct.
This vibration is being exaggerated at the moment because i have been running my 4.27 which has changed my driveshaft speeds in some areas of some tracks and now that vibration seems more evident.
Thanks in advance for anyone that has any info.
Cheers
jimmy p
Cheers
jimmy p
