Anyone know if the Getrag 240 and ZF320 have the same input shaft spline size/clutch compatibility?
Currently have a getrag 240 in my M52 318is, planning on swapping a ZF230 in. Previous owner put a nice single mass M20 flywheel and south bend clutch in it (I assume he used a euro 323i throwout bearing). Would like to use that setup with the ZF320 if it is possible.
Thanks!
Thanks!
