Driveshaft came apart while pulling the diff
  • mach schnell
    • Apr 2008
    • 1059
    I was in the process of removing the diff from my ‘89 325i... as I pulled back on the diff, I didn’t realize the driveshaft was still attached (even though the 4 bolts were removed), so the rear half of the driveshaft came out of the car with the diff. It came out very easily, with little to no resistance.
    Do I just push it back down into the front half?
    Or do I have to align it in a particular manner?
    Don’t want to have driveshaft vibrations from putting it back together wrong.
  • e30austin
    • 15382
    The front and rear u joints need to be in plane with each other, so yes, you will need to properly orientate it.
    The factory (usually) marks the two halves, with a white dot, on each side, respectively.
    • mach schnell
      • Apr 2008
      • 1059
      Argh. Ok. Thanks. Do I have to pull all of the exhaust and heat shielding to be able to see those marks....???
      • e30austin
        • 15382
        Unless you have x-ray vision, yes.
        You will need to take the driveshaft out of the car.
        • mach schnell
          • Apr 2008
          • 1059
          Dang it.
          I was really hoping to avoid that. What a pain in the ass.
          Thanks for the info!
          • mach schnell
            • Apr 2008
            • 1059
            If there are no white marks, how else can I align it properly?
            • roguetoaster
              Biggus Tippus
              • 7815
              Look for any scratches or other type of indicator of alignment. Otherwise you're screwed.
              • mach schnell
                • Apr 2008
                • 1059
                Have to take it to a driveshaft shop at that point?
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  Like Austin said, the u-joints just need to align with each other. They can only align 2 different ways. More than likely it won't vibrate in both position.
                  • mach schnell
                    • Apr 2008
                    • 1059
                    I got it back together. I found the white marks, and I think it’s together correctly. No vibration so far....
                    Thanks for all the help.
