E30 Drivetrain noise
  • Leonstt
    • Feb 2019
    • 81
    Hi guys,
    I notice when I was driving down a highway, I heard some sewing-machine like noises coming from somewhere in the driveshaft/diff area of my car. The noise sounds like a rotating part touching something and only noticeable when doing 40mph and above and gets worst when the road is bumpy. And dissappear as I slow down. Anyone has any idea what is going on with my Drivetrain?
  • Leonstt
    • Feb 2019
    • 81
    here's a video showing how it sounds
    • tomstin
      • Mar 2015
      • 568
      You need to get under the car, my guess is the flex disk (rear of the transmission) (which you can see without removing anything) or the center support bearing which you need to pull the rear exhaust and shields to inspect. Also, the rear universal joint at the rear of the driveshaft which you can also inspect without removing anything.
      2004 525i Manual - 1985 325E Coupe Manual
      • Leonstt
        • Feb 2019
        • 81
        Thanks for the reply
        Would failures of any of the parts you mention cause vibrations? I don't feel any vibrations at all. Just the noise
        • tomstin
          • Mar 2015
          • 568
          I would expect the universal joints to make more noise than vibrate. The flex disk and center support bearing tend to vibrate. Of course then you have the half shafts on the rear axle, the wheel bearings and the rear gear itself. Running it on a lift may be helpful but then the suspension is hanging and all the geometry is different. But under the car, with that noise, I doubt if the noise will be hard to locate.
