Thought I’d try and get some opinions here.
Changed the clutch slave cylinder on my g260 after installing a clutch masters fx350 and now it has trouble going into first gear (only when the car is hot and has been driven 20+ mins) otherwise it works perfectly which is very frustrating. I’ve bled it 4-5 times using different methods and at first it seems fine because it shifts easily into gear. But once you drive it about 20 mins or so and the car gets nice and hot it doesn’t want to go into first gear anymore from a standstill. I either have to force it in or shift into second and then back into first. It also goes in more easily when rolling to a stop.
I have since replaced the new slave cylinder for another new one, replaced the clutch line with a steel one, replaced the trans fluid and bled the system again... still has the same issue. Any ideas? I just want to enjoy driving my E30 :(
