Won't shift into second @ redline?
  • Groove_D
    • 131
    Hard to shift into second at the redline, anywhere around 5k it shifts ok. The shifter bushings are worn out, could that be the cause of it?
    I'm also running single grade HD oil SAE 20. Maybe it's too thick? But that's what the manual calls for.
    Anyone had similar issues? Thanks in advance.
  • dashboardmonkey
    FUCK YOUR WAFFLES
    • Jun 2008
    • 6158
    I have the same issue.
    My shifter bushings are also fubar.
    If your shifter bushings are fucked and you have a stock shifter, the shifter itself hits the the tunnel when you try to shift fast. At least that is what I noticed on mine.
    -Andy
    • Liam
      • 753
      Whoa, what book is that?
      2nd gear syncro is particularly prone to damage in these things.
      You should be running either Dexron ATF (better yet Redline's MTL) in an orange label trans or GL-4 (again better yet Redline's MTL) in all others.
      I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
      • Groove_D
        • 131
        He might be right cause everytime i select revers the shifter rubs on the console. And i noticed when i shift slower it shifts ok at least on the street. I didn't try to shift slower at the track; although, i should have.
        Liam, i have bmw electronic manual and it says to put in heavy duty single grade oil 20, 40 depending on climate. It also says you can use atf.
        • rThor432
          • Feb 2007
          • 3907
          Redline 75w90 is your friend.
          • nickpdx
            • 679
            Yup, Redline MTL/75w90 is always going to be your best tranny fluid option...stuff works miracles
            Sounds like bushings or perhaps syncro issues
            • gearheadE30
              • Jun 2007
              • 3734
              Redline MTL all the way. It is fine to use it in both the green and orange label boxes.
              Project M42 Turbo
              • Groove_D
                • 131
                Put redline 75w90 NS and shifts like butter. Thanks guys.
                • rThor432
                  • Feb 2007
                  • 3907
                  Excellent, good that it solved the problem.
                  • nickpdx
                    • 679
                    Amazing what sort of problems the stuff will cure!
