So I was able to purchase the motor and transmission from an imported 320i. Im going to use the motor to create a stroker and would like to convert the auto in my car to the manual.
The transmission is a getrag 240, which as I understand it, only came on the 4 cyl US cars. However, this version of the 240 mounts onto the M20. Does anyone have any experience with this swap in particular? I have read that there were specific motor mounts used in the 320i to offset the shifter angle. I also don't know if the shift linkage from a getrag 260 would work in my setup. Any help is greatly appreciated, thank you!
