Need some CV axle measurements!
  • iamsam
    • Jun 2008
    • 176
    I don't have an E30 right now (I have an E28), so if anyone has some E30 CV axles kicking around, especially if they are shot, I would love to get some dimensions!
    I need dimensions on the actual steel shaft itself, and the splines of the steel shaft that are inside the CV joint itself. I need to know what the spline count is, the OD of the splined section, and the overall length of the shaft itself, NOT including the CV joints.
    Can anyone help?
    I can give you an internet high-five....
    Thanks
  • Sampson
    • Aug 2020
    • 16
    So I have a set - but all the boots and joint are good and I'm not going to pull any of that apart since I'd like to sell them.
    Can I get you the dims you need?
