X20 - C101 using 530i harness starter wiring questions
  • Accomplish
    • Feb 2018
    • 189
    Hello all, I am likely overthinking this but can someone break down the starter wiring when using the b30 harness? I am getting no crank. There is no PIN 15 black/green on the X20 side when using the 530i harness. Where should my black/green coming from c101 side be going? Currently I have the large red 2g wire going from the large post on the starter to B+ and then the long black/green and black/yellow starter wires going to the other two posts.
  • Accomplish
    • Feb 2018
    • 189
    solved my own issue. Was overthinking it and didnt have the black/yellow wire attached inside the car to the ignition switch
