5.0 swap? Anyone actually finish one?
  • liv2race
    • 46
    Has anyone actually finished and posted up after it was running with the set up?
    Cant find it anywhere!
  • xwill112x
    • Jan 2009
    • 4236
    havnet seen it done, but waiting for someone to do the new 5.0 swap, 444lbs, all aluminum, & 412hp STOCK :)
    • justin_l_
      • Jun 2007
      • 1079
      I haven't found anybody who knows anything about in...
      • Garageaholic
        Freestyle Fabricator
        • Dec 2005
        • 5204
        a guy on the forum did an ls1 swap...that's 5.7 liter and much more of an impressive swap.
        Recent Rebranding!!
        E30 SM62/S62
        E30 M60 V8
        E30 M30 Big 6!
        Instagram.com/garageaholic
        Youtube.com/garageaholic
        • justin_l_
          • Jun 2007
          • 1079
          Was it the ls1 or the 5.3?
          • xwill112x
            • Jan 2009
            • 4236
            ls1
            • justin_l_
              • Jun 2007
              • 1079
              Originally posted by xwill112x
              ls1
              I've only seen this gm based build with a 5.3, lots of good info if it's your thing though
              • payney8
                • Jun 2007
                • 899
                Any more info? im looking at this or a 1uz
                • garretvs
                  • 464
                  We're the LS1 guys. See our other threads:
                  E30-LS1 aka. 357is
                  email us to pick up our LS1 swap guide
                  E30-LS1 KITS now available!!
                  E30LS1@gmail.com
                  e30ls1.com
                  • Iain
                    • Oct 2005
                    • 2815
                    Way too wide.
                    There is a lot of work involved for us to do an LS1 swap in Oz. Are you able to do it yourself at home? If not, this swap will be too expensive
                    http://www.r3vlimited.com/board/show...&highlight=ls1
                    There's a few other guys who've done 5.3L iron-block swaps.
                    Other alu 5.7L swaps:
                    iflytii with his race car (e30tech)
                    Blip Bavarian's "Blue Lagoon" project on here
                    Pork Hunt Motorsport
                    eBay is like the summit racing catalog for today's special Olympics crowd
                    • payney8
                      • Jun 2007
                      • 899
                      Originally posted by Iain
                      Way too wide.
                      Hey mate yeah i am i have a full fab workshop at my disposal. Are you saying there's more involved due to the adaption that bmw had to make. I.e. Brake rod, RH power steering arm
                      • mikespeed95
                        • 5
                        It also costs 3-4 times what a 5.0 would for a motorset.
                        OP, why are you asking if anyone has finished one? Are you stuck or are you contemplating?
                        1UZ are awesome as well for the dollar, and my old roomate in Florida sells the bellhousing adapters at xatracing.com
                        Mike Peters
                        80 Subaru Brat LeMons car - 72 Camaro drift project - Supercharged LS1 240sx
                        www.therustinthewind.com - youtube.com/mikespeed95
                        'Merica
                        • Vince30
                          • 2318
                          Not for e30s but this might be helpful.
                          • Iain
                            • Oct 2005
                            • 2815
                            You have to move the booster. Some use a remote-mounted unit, with new pedals and all new hardlines run through the car. I'm giong with a master cylinder mounted where the battery tray is (was) with E36/E46 pedals. This is a fuckload of work to set up correctly.
                            Powersteering will be tighter than a fish's arsehole. I've ditched power steering on mine to give myself more room, but it'll still be tight. Good luck gettting 1 7/8" headers in there, probably have to go with 1 5/8"
                            You'll have to get the loom repinned to suit the holden ECU.
                            You'll have to upgrade the brakes
                            You'll have to do a little massaging of the trans tunnel to fit the T56
                            etc, etc.
                            • payney8
                              • Jun 2007
                              • 899
                              So same amount as a 1uzfe basically. And brakes etc is common sense if your doubling output power. im going a uuc front kit and just rekitting the rear.
