M60 Swap thread
  • Jean
    • 18228
    #31
    ^ convert it to obd1.
    • naika
      • 466
      #32
      Thanks, sorry to thread jack again.
      Would that mean installing all the M60 harness, sensors, ECU?
      344is! Obd1 conversion
      • Jean
        • 18228
        #33
        Yep
        • naika
          • 466
          #34
          THanks!
          I'm looking into doing that, trying to figure out all the problems I'll run into
          So far, seems like the cranck sensor needs placed on the front pulley and replacement of the thermostat and water pump.
          Good luck with your build, Il'l keep my eye on the progress
          • naika
            • 466
            #35
            THanks!
            • sacbmwdriver
              • Aug 2009
              • 422
              #36
              do you plan on BAR'ing your car? also do you think that instead of making some engine mounts would these mounts be better? http://66.163.168.225/babelfish/tran...p5%2ftyp5.html
              Oh yeah and im from Sacramento also what area do you stay? ill be looking forward to seeing this car on the road!
              • Jean
                • 18228
                #37
                Yeah, I'll have to BAR it again... since I've gone through the process already it's not that bad.
                I've seen those mounts as well, might be able to get something locally first otherwise I'll look more into those..
                • e30polak
                  • 6136
                  #38
                  Nice Jean! I would've chosen an OBD1 M62b44 personally, but the m60 will be MUCH more fun then your m30! :D
                  INSTAGRAM: @UNDR8D_EMPIRE
                  • george graves
                    • 20003
                    #39
                    I support this thread.
                    Originally posted by Matt-B
                    • Jean
                      • 18228
                      #40
                      Me too, but obd1 m62s do not exist lol. It appears that converting m62 to m60 PROPERLY w/o a hack job is proven to be more difficult.
                      from moroza on bfc - "you can swap M60 timing covers and gear if you do one of the following bits of custom fabrication: spacers for M60 cams to fit onto M62 heads, or M62-bore headgaskets to mount M60B40 heads onto the M62 block. Otherwise, no."
                      full thread here - http://forums.bimmerforums.com/forum...919713&page=12
                      • e30polak
                        • 6136
                        #41
                        I was thinking just using the intake manifold, lol. :p
                        • george graves
                          • 20003
                          #42
                          So - I'm confused. You want the m62 for the displacement, but the m60 for the obd1 non-vanos head, right?
                          • CorvallisBMW
                            Long Schlong Longhammer
                            • 13039
                            #43
                            Why not just bore out the m60 and throw in m62 crank/rods/pistons? No head swapping or obd1 conversion junk to deal with.
                            • e30polak
                              • 6136
                              #44
                              I mean to leave it OBD2 and put an OBD1 intake manifold on it. They flow better, much like the 24v engines.
                              Vanos > Non-Vanos any day.
                              • Jean
                                • 18228
                                #45
                                Well, I don't know if vanos is worth the trouble on the m62.. When I was troubleshooting it on the e39 and disconnected it, car felt just as quick in the mid to high rpm range and was only slightly noticable in the low rpm range. So, to me non vanos v8 is fine.
                                George - yep, some dyno as much as 270whp... I haven't looked at what options are out there yet in terms of bigger pistons etc. I really don't want to drop 5k into the motor or anything like that, just a nice clean re-fresh/reseal and call it good you know.
