Spinoff from another thread, didn't want to hijack...
Could you just run a P/S fluid res from a hydro-boost car (e28 535i), and a booster/accumulator (e28 535i) with the master cyl of a hydro-boost car (e28 535i). See what I'm getting at here?
e28 535i
Plumbing would be a cinch, as there is no need to have a different P/S pump. You'd just have to swap the reservoir and install the related accumulator/brake parts. Since e28's didn't have any of the traction control and self leveling shit, but did have ABS I see no real problem. Everything should be in relatively the same position as the e30 stock booster/MC setup, so running all kinds of hard lines and shit would be moot. The reservoir to P/S rack and pump are soft lines. You'd just have to make sure the lengths were correct, which I would assume in using e28 parts they would be as on the e28 everything is on the same side of the engine bay (right).
Bam.
I have an e30 shell and e28 shell with brake/P/S parts I will test fit the MC/accumulator parts on this week.
Problem? Looking for some input.
e28 535i
Bam.
