Junkyard M62
  • Mr Two
    • Jul 2008
    • 590
    Junkyard M62
    Found this baby sitting in a '96. Seems like if could be a great candidate for an M60 / M62 hybrid, but I need to find out if the motor is fudged.
    I don't think I can do a compression or leakdown test, so it seems my only option is to go back on thursday and yank the heads to see what's up. I've heard these motors are pretty tanky, so I'm hoping it's alright. Any recommendations?
  • bmwmech1
    • Jun 2010
    • 1075
    What's the rest of the car look like? Is there any accident damage? Chances are pretty good that if it didn't end up in the yard for a wreck, it was probably the transmission that gave up. I just replaced one in a 98. Mileage? Drain the oil and look at it closely. If there were any bearing issues, they'd show up in the oil. Pull the plugs and look at them and take a 27mm socket and breaker bar and spin the motor and see what it feels like. Don't kill yourself tearing it apart in the yard... if you can get it for cheap, just yank it and tear it down at home...
    Garey
    • E30SPDFRK
      • 5690
      If the intake and oil caps have been off for longer than a (dry) day, I wouldn't touch it.
      Byron
      Leichtbau
      • Jean
        • 18228
        Pick that up for $200 or whatever it costs at junkyard, and go to town. Open it up, If it's bad, just bring it back and get credit for it . Otherwise have the heads checked/re-done , new bearings, top/buttom gasket kit, timing components.
        • Mr Two
          • Jul 2008
          • 590
          Anything special I should know before I go and crack off the heads?
          I'll probably just end up using the block, as I'm looking at putting together a hybrid like bmwmech1's
          e: I'm going to finish this stupid homework and try and make a compiled M60 swap thread.\
          e: Anyone know if the bolts holding the trans on are weird torx ones?
          • Jean
            • 18228
            If anything I would keep the heads on there, and see about doing a compression check. Then do the usual stuff, my brothers 03 m62tu with 130k already had some rod bearing wear showing , little but still there. So, on a 96 I would deff do as much as possible while it's out. Oil pumps are sometimes an issue on these as well, usually on the early engines.
            You'll find out that not many engine shops will touch these engines at all (blocks specifically).
            • bmwmech1
              • Jun 2010
              • 1075
              Yes, they are E10 and E12 inverted torx bolts...
              Garey
              • Mr Two
                • Jul 2008
                • 590
                Well fuck, I guess I need to go buy those, lol
                • RobertK
                  Kicked cancer's ASS.
                  • Jun 2005
                  • 5864
                  If you need a good M60 I have one from a 1995 740il locally for $800. Clean car, wrecked on DS fender, engine in good shape and kept covered, nothing has been touched on it. Comes with everything you should need. (ECU, wire harnes, MAF, etc.) not a hacked up Pull-a-Part engine I promise.
                  I'm close to you in Knoxville, TN so LMK if you are interested and we can work something out.
                  • Mr Two
                    • Jul 2008
                    • 590
                    We've met, I'm Corey, with the brown car. This M62 is in the local pull-a-part :D
                    I'd be interested in the coming weeks, probably after the last track day of the season.
                    • RobertK
                      • Jun 2005
                      • 5864
                      Sup Corey! I wondered if that was you considering the name.
                      LMK, I'm little flexible on the price since I don't really have a need for it right now.
                      Actually came in here to post it up for sale to see if anyone would be interested and found your thread.
                      • bmwmech1
                        • Jun 2010
                        • 1075
                        You'll need the E12 for the head bolts on the M6x motors, too, so at least you can justify the cost, lol!
                        Garey
                        • Mr Two
                          • Jul 2008
                          • 590
                          Might be picking it up Saturday, assuming it is still there. I'm waiting to hear back from VAC Motorsports, first.
                          • RobertK
                            • Jun 2005
                            • 5864
                            I was wrong, the engine I have is a M60B40.
                            Clean as hell though. Per the oil change tag it was due for its next full synthetic oil change at 91,135. Car was very well kept its a shame that it was wrecked.
                            • Mr Two
                              • Jul 2008
                              • 590
                              You mean an M60b40?
                              Still haven't picked up that motor - waiting to hear from VAC. I may pass on it, and wait till I have more detailed plans together.
