My BMW V8 engine build thread
  • Jean
    • 18228
    #46
    Hey Frank, 200 including cleaning and pressure testing etc
    They've done the m62tu heads before and was about 500 including taking cams out and to Rebuild all lifters .
    • Jonsku
      • Oct 2004
      • 566
      #47
      By "rebuilding" you mean "replacing", or can they actually be rebuilt? (other than washed / cleaned properly?)
      - E34 M5 (x 2) -
      - E30 V8 Cabrio "Kylpyamme" -
      - Alpina D10 Touring #33/94 -
      - E46 318i Touring -
      - Toyota Hiace 4wd -
      • Jean
        • 18228
        #48
        I meant each lifter was opened to clean internally and then put back together.
        • 328ijunkie
          • May 2007
          • 3961
          #49
          looks pretty
          Check Us out on Facebook
          Full Product Line Tuning
          • Garageaholic
            Freestyle Fabricator
            • Dec 2005
            • 5204
            #50
            Now if you get the heads resurfaced, should you (do u have to) get the block resurfaced as well?
            Recent Rebranding!!
            E30 SM62/S62
            E30 M60 V8
            E30 M30 Big 6!
            Instagram.com/garageaholic
            Youtube.com/garageaholic
            • Jean
              • 18228
              #51
              Depends if they are messed up or not, I bought the smalled possible filler gauges and on the m62tu where both heads warped to 0.006 the block was still perfectly straight.
              • weaksauce
                • Apr 2009
                • 550
                #52
                just to verify my reading here....
                you're using a rotating assembly from a B44 and heads form a B40, right?
                which cams?
                which springs?
                which manifold (intake)?
                Did you CC the heads to verify the b40's had a smaller combustion chamber?
                how do the intake and exhaust ports look on the 2 versions of the heads?
                what are your HP goals with the car?
                I am building a M62 as well, and I really want 350 RWHP with it, so I'm doing a dry sump setup on it as well as looking at other mods to get me there.
                • The Dark Side of Will
                  • Jun 2010
                  • 2796
                  #53
                  350 WHP is going to be 400 or better at the crank... That's S62 power. You'll need some serious work to make that happen with 4.4 litres.
                  • iamsam
                    • Jun 2008
                    • 174
                    #54
                    My guess is the M60B44 conversion will get you just a little above 300hp at the crank.
                    • Jonsku
                      • Oct 2004
                      • 566
                      #55
                      M60B40 will make slightly over 300hp at the crank with remap, so when increasing disp & CR by 10% you should be getting 330hp at the crank (in ideal world at least)..
                      - E34 M5 (x 2) -
                        • Jun 2010
                        • 2796
                        #56
                        320-330ish at the crank was my guess also.
                        280 +10% for displacement is 308 plus a moderate fudge factor for compression + tune.
                        IE, if you crack 300 RWHP using stock hard parts, you're doing pretty well.
                        Now if you're going to have a lot of head & port work, full build with custom pistons, sell your house to buy cams, etc, then you'll get to 350 RWHP after quite a few $$$.
                        • Jonsku
                          • Oct 2004
                          • 566
                          #57
                          300 rwhp means roughly 350 hp at the crank, which is maybe bit far for ECU-tuned M60B44 .. ?
                          Anyhow, looking forward to actual dyno-curves of these engines - sligth head-work and cam-grinding could well put you to 375hp range which starts to be something :)
                          - E34 M5 (x 2) -
                          • weaksauce
                            • Apr 2009
                            • 550
                            #58
                            my 540 (m62b44) dyno'd 282 to the rear wheels with just software on it.
                            so in doing a custom dry sump, custom intake and stand alone, I am hoping to do slightly better than just 18HP.
                            but I just don't know what to expect.
                              • Jun 2010
                              • 2796
                              #59
                              Custom intake manifold or custom intake tube?
                              All the bolt-ons in the world will only take you so far with stock cams.
                              • iamsam
                                • Jun 2008
                                • 174
                                #60
                                That's weaksauce.
                                Anyway, 330hp is a believable number, and w/ 15% drivetrain loss that would be around 280 whp.
                                Jonsku, what kind of re-flashing are you taking about? Just an off-the-shelf chip? I doubt anyone has tuned an M60B44 conversion to make a chip.
                                What do you do to get a regular old M60B40 up to 300 bhp?
