So this morning before I fell asleep (I work nights), I was thinking about how I'm going to do the booster set up in my E30 for the M60. I've already gone through a lot of build threads on UK E30 forums looking how they did mounted up theirs. Their stock boosters are in the same location as LHD, but RHD just has a crazy linkage for the pedals to work.
Anyway my plan is to relocate the booster before I start the swap to get any possible gremlins worked out. Everyone seems to have their own variation of 3 methods of mounting the booster securely. Either they make their own mounts, try to use the factory E32/E34/E39 mount, or a hybrid of those two.
For my swap I think I'm going to buy one of these setups for LS1 swap E30s. They run into the same problem as us of where to mount the booster. I want something that's pretty much bolt in.
Problems I foresee:
So thoughts?
Problems I foresee:
- How thick is the rear section of the linkage that mounts to the firewall?
- Where it's designed to mount, you can't use a vacuum booster. So either you would have to use hydroboost or move the front mount farther up, relocate the ABS unit, and then get a longer crank.
- Side mount will need to be either relocated or fab up a mount towards the front it can use.
So thoughts?
