Possible V8 donor?
  • MattAvino
    • Jan 2011
    • 2147
    Possible V8 donor?
    Should I check this one out?
    E30 buildy things
    http://www.r3vlimited.com/board/showthread.php?t=195286
  • battlecattle
    • Feb 2012
    • 72
    Yes and no
    200hp V8... no thanks
    complete running and swappable... sure
    Up to you
    -Josh
    M60 E30
    • dirty30
      • 3008
      Good trans/ brake hardware/ engine harness donor. I'd throw the engine away.
      • ttrousdell
        • Nov 2009
        • 1770
        get the the 4.0L m60 if you want to swap a V8 bmw engine.
        The Build:
        • bmwmech1
          • Jun 2010
          • 1075
          That is what I bought as donor for my build way back when... the only thing I ended up using was the trans, but my build quickly morphed into a much bigger project. As stated above, the engine harness, transmission and brake booster/linkage is about all that is worth keeping for a swap. There is plenty to be sold off, though. I don't know if you'll recoup your purchase price, but that's your choice. The engine itself, steam cleaned and detailed, makes a nice coffee table base, but that's about all it's good for...
          Garey
          • Jean
            • 18228
            M60B30 is crap, don't, not for $2500!
            • MattAvino
              • Jan 2011
              • 2147
              Thanks for the info. I was thinkin that the B30 was poo, but it has a good trans and other parts. And I probably wont get much for the shell due to the trashed 1/4.
              good interior though.
              E30 buildy things
              • The Dark Side of Will
                • Jun 2010
                • 2796
                You could probably recoup the money in parts sales, but I wouldn't pay $2400 for it... you can get unwrecked running cars for that much.
                Nice shift knob though.
                • iamsam
                  • Jun 2008
                  • 173
                  I'd look for a wrecked car to buy. You WILL need that trans, but like everyone else has said, the engine is worthless, other than all the little crap that is interchangeable w/ the B40.
                  Finding the 6-speed is hard, and $$$, it is easier to find the ZF 5-speed (in that car you linked), and I hear (on this forum) that the ZF length allows for factory driveshaft fitment, as well as flange fitment, and modifying driveshafts is expensive.
                  Sorry about the tangent...
                  • bmwmech1
                    • Jun 2010
                    • 1075
                    Originally posted by iamcreepingdeath
                    ... and I hear (on this forum) that the ZF length allows for factory driveshaft fitment, as well as flange fitment, and modifying driveshafts is expensive.
                    This is accurate. OEM E36 328i driveshaft is P&P with the 5 speed, all factory hardware, E30 center bearing, 5 speed flex disc. Everything bolts together, no mods at all...
                    Garey
                      • Jun 2010
                      • 2796
                      The 5 speed used with the V8 is exactly the same 5 speed used with the M50, except is has the V8 bellhousing.
                      Thus the V8 5 speed is plug/play with the "standard" M50 swap driveline parts.
