M60 Swap: List of parts to take from donor car
  • iamsam
    • Jun 2008
    • 174
    So I looked around and I didn't see a thread for this specifically, and if there is one, mods please feel free to delete this one.
    To swap an M60B40 from an E34 540i or E32 740i, what parts do I need to take from the donor before I send the entire car to the crusher?
    My list so far:
    • M60B40/wiring/ECUs
    • Exhaust manifolds
    • Front half of driveshaft (if applicable)
    • Coolant reservoir and related hoses
    • Throttle cable
    • Diagnostic port mounting hardware
    • Manual trans/slave cyl/flywheel/clutch (if applicable)
    • Remote brake booster and all bracketry/reservoirs
    • Brake calipers, lines, pads, and rotors (if swapping to an E28, like I am)
    Is there anything else? I just want to make sure I get EVERYTHING I need before the car is gone for good.
  • bmwmech1
    • Jun 2010
    • 1075
    Uh oh... you have caught the sickness for real, haven't you, lol?
    Accelerator cable and diagnostic port mounting clip come to mind, since I didn't grab these from my donor car... I'm sure there are more I'll think of...
    Garey
    • senorcarey
      • Apr 2012
      • 80
      The trailing arms will bolt up as well, as the 740 trailing arms have the roller bearings instead of bushings. I don't believe the 540s have these.
      I have this set-up attached to an E28 subframe in my E3.
      See if the diff is an LSD. Really, grab as much stuff as you can that you might be able to turn a profit on.
      • iamsam
        • Jun 2008
        • 174
        Garey
        I've had the sickness for a while now! And I have had the donor car for a while also, but I only just now found time to pull the motor out of it. I have to scrap the donor quick though, I need to clear garage space for other cars (and engines)
        Is there anything else I am missing in my list?
        • iamsam
          • Jun 2008
          • 174
          whoa, so the E32 rear trailing arms have the same exact geometry that the E28 ones do??
          Unfortunately, the diff is open. Either that, or a really dead LSD. Does an E32 diff mount to an E28? is an E32 rear subframe the same as an E28 (since the arms are)?
          • senorcarey
            • Apr 2012
            • 80
            The E32 arms do have the same geometry, but the hubs have different spacing which gives it a slightly wider track by about 8mm/side, if I remember correctly. Not an issue on my car, but can be on a space challenged E28.
            I'm pretty sure the subframes are different between the E32 and E34 and I know that both are different than the E28.
            • iamsam
              • Jun 2008
              • 174
              It seems like E38 style 5s with 225/50/16 rubber can stand to move out another 8mm with minimal issue. Maybe fender rolling will be required, though.
              • senorcarey
                • Apr 2012
                • 80
                Yeah, those are et23 if I remember correctly. I was running a staggered set of Style 32s (et26 17x9) with 255/40/17 and they still had plenty of room. I am on Style 9s (et15 16x7.5) now with 205/55/16 and they fit about the same. It's the front where I am spatially challenged.
                I should mention that I believe the trailing arm part number is the same for E32 740/750 and E34 M5. It is still a bolt up to the E28 subframe, though.
                • iamsam
                  • Jun 2008
                  • 174
                  ^^ very good information.
                  • Jean
                    • 18228
                    Exhaust manifolds?
                    Front part of the driveshaft or the whole driveshaft so you have something to work with / modify?
                    Complete engine/tranny is a good start.
                    • iamsam
                      • Jun 2008
                      • 174
                      ^^ I totally missed that. Added to list.
                      • BruceBe
                        • 108
                        Coolant reservoir and the strange hoses that lead to it. I recall using/modifying at least one of those hoses to complete my cooling circuit.
                        You'd also want the DME (ECU).
                        -Bruce
                        • iamsam
                          • Jun 2008
                          • 174
                          -Bruce
                          G'day, Bruce! Good call on the coolant bits.
                          • iamsam
                            • Jun 2008
                            • 174
                            So, what about steering parts? What power steering lines need to be transferred over? I am assuming the PS pump orientation on the M60 is not exactly the same as on a stock M20... ;)
                            • bmwmech1
                              • Jun 2010
                              • 1075
                              None of the lines will be needed from the donor car. You can re-use your feed and return lines, most of use have had a custom pressure line made. Those are the only 3 lines you need. Most NAPA's can make up hydraulic lines to your specs...
                              Garey
