Cam Timing
  • senorcarey
    • Apr 2012
    • 80
    Cam Timing
    Since I haven't seen any posts on how to accomplish this, what is the correct way to time the cams with the "new" timing from BMW. If the cams are locked in place with the tool, do you degree the cam sprocket?
    Thanks.
  • dirty30
    • 3087
    Thanks.
    Lock the crank, lock the cams, insert the dummy tensioner then torque the cam gears. That's all there is to it.
    • Jonsku
      • Oct 2004
      • 566
      "old" timing = all four cams are aligned perpendicular to the heads
      "new" timing = cams in other bank (drivers side?) is tilted slightly
      The tools have alignment accordingly.
      - E34 M5 (x 2) -
      - E30 V8 Cabrio "Kylpyamme" -
      - Alpina D10 Touring #33/94 -
      - E46 318i Touring -
      - Toyota Hiace 4wd -
      • senorcarey
        • Apr 2012
        • 80
        Excellent, that makes much more sense to me. I thought that it would be a pin to have to do it the way I was thinking. Thanks for your help!
