Fuel return and Charcol canister?
  • eurotrash
    • May 2007
    • 768
    So my carbed v8 setup has been run "dead head" style without a fpr. Im putting a return style fpr in but i dont see a clear return line. It looks like the return line runs into this canister. Not real sure what it is or why the fuel/vent lines run into it. Also the return line should be the outboard line that runs along the frame rail and the lowest line at the bulkhead correct?
  • Jonsku
    • Oct 2004
    • 566
    If you've V8 swapped E30 the fuel lines most probably are not like in stock, so you better trace them under the car and see what goes where.
    Charcoal canister is not a "fuel return point", but a vent for the tank..
    - E34 M5 (x 2) -
    - E30 V8 Cabrio "Kylpyamme" -
    - Alpina D10 Touring #33/94 -
    - E46 318i Touring -
    - Toyota Hiace 4wd -
    • Etexise30
      • Sep 2012
      • 208
      can you share your stories on how you did your fuel line Jonsku? iam on the same boat as him.my m62 rail only has one inlet and not two like M20.
      • Jonsku
        • Oct 2004
        • 566
        I built my car completely from scratch, so I know precisely what line and wire goes where and what is the function of each.
        Take your time and study things / the car.
        - E34 M5 (x 2) -
        • Etexise30
          • Sep 2012
          • 208
          oh yeah i know about time man.... jeez this thing is a puzzle :) ok ill do more research on it :).iam in no hurry with this car anyways iam still working on the vanos harness and ews
          • robiniscool
            • Jul 2010
            • 299
            looks like you have the obd II fuel rail, just look for the obd I one it has 2 inlets, way easier and same mounting holes whether its obd I or II intake manifold
            • eurotrash
              • May 2007
              • 768
              The lines under yhe car are all stock. I doubt the guy that originally swapped it was smart enough to run a 2ndary charcoal canister for the return line based on the crap he did everywhere else but there should only be a feed return and a vent line from the stock tank right? Right now ive got a def feedline from the pump and the other 2 run up into this canister.
              • eurotrash
                • May 2007
                • 768
                I was under the impression that the charcoal canister was it the rear wheel well if it has one and there was only 1 ventline running to it from the tank.
