hey guys done the head gasket on my 318is and cooked the motor, Im looking at a few options. One of them is a v8 swap, In Australia its hard to find the 4.0l for cheap. There seems to be an abundance of the 3.5l is it worth doing this swap?
3.5l worth it?
Here in the USA it is a popular swap, and there are quite a few threads here to guide you through it. FrankM E30 has a free searchable PDF file with details. Info on that ITT: http://www.r3vlimited.com/board/showthread.php?t=231570
You might want to check with some of the Aussie members of the board to get info on licensing and inspection as I believe that varies from state to state in Australia.sigpic
Originally posted by JinormusJDon't buy an e30
They're stupid
1988 325 SETA 2DR Beaten to death, then parted.
1988 325 SETA 4DR Parted.
1990 325i Cabrio Daily'd, then stored 2 yrs ago. -
There's no 3.5 variant from M60, they only come in 3.0 and 4.0 litre capacities.
The newer V8, M62, comes with either 4.4 or 3.5 litre capacity.
Basically all of those swaps are the same, though newer engines are a bit more complicated with all the electronics etc.. IMO the smaller ones are not worth the hassle, go straight for "big power" (=largest displacement). Anyhow, you could build it up with the smaller engine and once everything is sorted out, swap a larger displacement engine in there..- E34 M5 (x 2) -
- E30 V8 Cabrio "Kylpyamme" -
- Alpina D10 Touring #33/94 -
- E46 318i Touring -
- Toyota Hiace 4wd -Comment
Do it.. You can always upgrade to a 4 or 4.4 later!
but you'll always have a V8..!https://www.forabodiesonly.com/mopar...re-irs.356333/
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.Comment
