Subframe Spacers 0mm, 10mm, 20mm
  • alco
    • Feb 2013
    • 197
    In reading various threads both in English and in translated German, it has yet to be fully explained why the three different options. I understand that with the 10 and 20mm it seems to promote better driveline alignment (at the guibo especially) but my concern is about the bump steer and screwed up suspension dimensions. Have any of you experienced this? Is there a remedy? I've also read that some have attempted to do the conversion without the spacer and that it isn't an issue with the E30 unlike in the E36 where it may not clear the steering rack.
    Velocity Motor Works
    1972 2002
    1983 533is
    1987 325is (Roxanne)
    1988 M6
    1989 M3
    1989 325ix (Darth Maul)
    Gone: 1974 2002, 1984 318i , 1985 318i, 1988 325ix Sedan, 1988 325ix Coupe, 1991 318is, 1991 318i, 1994 525iT, 1995 325is, 1996 M3 Coupe, 1997 328is, 2001 325i, 2001 Z3 2.5i, 2001 330i, 2001 525iT, 2006 F-250 SD and more...
  • E30SPDFRK
    • 5716
    Idk how bumpsteer has become what it is on this forum, but lowering the subframe won't cause the car to magically have more. What it effects is the roll center and it puts the control arms at a point on the camber curve that is even less desirable.
    It is also supposedly better for the guibo, but I haven't done the measurements to say for sure. I can tell you that I ran mine with no spacers and my guibo lasted just as long as it did when I had an m30, I had no vibrations and an extra inch of ground clearance over spaced subframes.
    Byron
    Leichtbau
    • alco
      • Feb 2013
      • 197
      Well this is why I ask because I do not know.
      1972 2002
      1983 533is
      1988 M6
      1989 M3
      • Jonsku
        • Oct 2004
        • 566
        I haven't noticed any real difference with or without spacers - have built one of each type.
        In my opinion it's better to use spacers as then you have correctly aligned driveline, and the biggest advantage is that you can use E32 / E34 - type expansion tank bolted to firewall above the engine. There is no other option that would work as well and problem-free.
        - E34 M5 (x 2) -
        - E30 V8 Cabrio "Kylpyamme" -
        - Alpina D10 Touring #33/94 -
        - E46 318i Touring -
        - Toyota Hiace 4wd -
        • alco
          • Feb 2013
          • 197
          Very good point Jonsku.
          I was planning on using the Mishimoto aluminum expansion tank mounted remotely myself. My motor is out of a 740iL and I don't want to source or cut up a new acoustic cover. I like the "all-the-way-to-the-back look."
          http://www.fcpeuro.com/products/mish...Fag7MgodLGgAvw
          1972 2002
          1983 533is
          1988 M6
          1989 M3
          • mark///m3
            • Oct 2007
            • 287
            As soon as my car is out of storage I will be pulling my subframe spacers. I am not a huge fan of how low everything sits now. I ave a coolant resevoir out of a w126 Mercedes so that won't be an issue for me. I will just have to remake my steering shaft.
            ___________________
            Mark
            • slammin.e28
              שמע ישראל
              • 12054
              I like MM's solution to the spacers. Turning the offset FCABs 90 degrees down.
              I'm a big fan of proper driveline alignment, so I got the spacers. Plus, the more room the better under that hood.
              • alco
                • Feb 2013
                • 197
                Can you elaborate on your solution slammin.e28guy? Who is MM?
                1972 2002
                1983 533is
                1988 M6
                1989 M3
                • The Dark Side of Will
                  • Jun 2010
                  • 2796
                  I wonder how much turning the offset CAB's affects brake dive...
                  • slammin.e28
                    שמע ישראל
                    • 12054
                    • alco
                      • Feb 2013
                      • 197
                      Thanks!
                      1972 2002
                      1983 533is
                      1988 M6
                      1989 M3
                      • E30SPDFRK
                        • 5716
                        It should get it closer to stock then using the subframe spacers alone.
                        Byron
                        Leichtbau
                        • dirty30
                          • 3112
                          I don't normally argue about stuff on here but this is incorrect and misleading for someone looking for solid info in the V8 subforum. Lowering the subframe would absolutely affect bump steer in a negative manner.
                          • fronton
                            • Oct 2009
                            • 1262
                            Angle of the driveline is the most important, suspension can be sorted from there. I am running 20mm spacers and 20mm RCS as well to correct the control arm geometry and have had no suspension issues. With roll center spacers you will need to run at least 16" rims.
                            • LJ851
                              • 7919
                              The steering rack mount and lower control arm pivot (ball joint) are both on the front subframe. Moving the subframe does not change their relationship to each other.
                              Anti dive would be slightly affected because the rear control arm pivot stays fixed, but any meaningful amount of bumpsteer has not been introduced.
                              Lorin
                              The M30 is God's engine.
