Frank Macaluso's E30S62 Swap Thread
  • Garageaholic
    Freestyle Fabricator
    • Dec 2005
    • 5204
    #46
    Originally posted by M3 euro ltw
    I didn't look back at the build thread for the M60 you've got to see which six speed gearbox you're chosen.
    I assume you know that if you have an early V8 six speed the bell housing isn't machined to accept a timing sensor as you will want for the S62.
    Alex.
    So I did some research on this topic. Looks like all early E34 540i 6 speed transmissions, while didn't have the holes drilled, at least had the mold in the bell housing cast, this makes EVERYTHING SO MUCH EASIER.
    After checking the wiring harness for the engine, it does in fact have a plug for such a crank position sensor. However, I still need to peel back the rubber grommet on the switch harness to match the colors with the wiring diagram just-to-make-sure.
    Here is a picture of the late model 6 speed, courtesy of Bavarian auto recycling. Just take note on the bottom right of the transmission where the crank position sensor is to be mounted.
    now check out my dirty ass early model 6 speed, which doesn't have the holes drilled, but has the mold for it. Easy - peasy - lemon - squeezey!
    Just bought a sensor, shim, and M6x16 screw for the installation from www.thebmwpartstore.com and I'm now back on track!
    Recent Rebranding!!
    E30 SM62/S62
    E30 M60 V8
    E30 M30 Big 6!
    Instagram.com/garageaholic
    Youtube.com/garageaholic
    • Garageaholic
      • Dec 2005
      • 5204
      #47
      Oh yeah,
      It looks like the flywheel is somewhat keyed to accept one single installation
      Recent Rebranding!!
      E30 SM62/S62
      E30 M60 V8
      E30 M30 Big 6!
      • MT325is
        • May 2012
        • 1103
        #48
        Do work! this is amazing yet again, and i will keep saying it about another 3 yrs after its done! love!
        1989 BMW 325is (SOLD)
        1992 BMW 325IC (SOLD)
        1991 BMW 318IS (STOLEN!)
        2017 BMW M2 (WEEKEND WARRIOR)
        1989 BMW 325IC (PROJECT(
        2002 FORD ESCAPE (DAILY)
        • F34R
          sLaughter
          • 12376
          #49
          So glad that quick connector worked. I know you will finish this up in no time!
          Instagram: @BWeissLeather
          Current cars:
          ~ '87 325 M30B35 swap
          ~ '87 535
          ~ 01 540 Msport 6spd
          ~ '06 X5 4.8is
          • the imitator
            • May 2013
            • 1006
            #50
            hey frank can I grab my e30 swap write up please! thank you sir!
            • F34R
              sLaughter
              • 12376
              #51
              BOOM! that easy...
              Current cars:
              ~ '87 535
              ~ '06 X5 4.8is
              • Turk
                • 223
                #52
                Looking great Frank!!!
                Did you receive my message about making up a remote 'level sensor' bottle? You could simply plumb it into the sump drain and have a breather to the top of the motor somewhere.
                Also its worth considering doing the big ends while the motor is out and easily accessible. With shells and gasgets and bits it'll cost you around £500 odd but well worth it!! you dont want that thing knocking. If you got any history with the engine check the receipts as it may well have been done already as its not an uncommon fault on S62's.
                Looking fantastic!!!!! SUB'D
                Plug and Play S54 & S62 loom/Ecu Kits - Fit you engine to ANY car!!!
                M50 Sump Baffles
                High Torque Clutch Kits
                Custom Flywheels
                E30 Engine Conversion Kits
                http://www.bmw.ergen.co.uk
                LIKE our Facebook page for regular car porn :)
                http://www.facebook.com/ergenltd
                • Garageaholic
                  • Dec 2005
                  • 5204
                  #53
                  Hey Turk,
                  I haven't gotten your email yet since i haven't been at work in a day or two. What are you referring to "not an uncommon fault on S62's"? What exactly is the fault you're speaking of?
                  I checked the engine and replaced the rear main gasket/seal and some oil o-rings. That's just about it. I didn't see any evidence of leaking, coolant corrosion on the aluminum, or any other signs of increased wear or tampering. I think that this is a pretty unadulterated S62.
                  If anything does come out of the works this summer through regular driving, I will overhaul the engine likely in the winter when I don't plan to drive it anyway.
                  Recent Rebranding!!
                  E30 SM62/S62
                  E30 M60 V8
                  E30 M30 Big 6!
                  • MT325is
                    • May 2012
                    • 1103
                    #54
                    Frank, get ready to make sell swap write up for this!:) a lot of people i think would be interested.. i sure know i am!
                    • Turk
                      • 223
                      #55
                      Hi Frank, Im referring to the shells, They often knock. (ps no email sent just mentioned it here) Sorry didnt mean to panic you, its just good preventative maintenance thats all.
                      If the car is coming off the road after the summer then you can analyse it all and do the necessary works, good plan.
                      A friend alerted me to a really good thread of S62 shells being done fyi:
                      http://forums.m3cutters.co.uk/showthread.php?t=65386
                      M50 Sump Baffles
                      Custom Flywheels
                      • M3 euro ltw
                        Site Sponsor
                        • 259
                        #56
                        CPS and shells vs bearings
                        Glad my pointer to you on the CPS helped you out.
                        Second, people should consider the ARP style technique of getting bolt stretch measured for con-rod bolts.
                        (UK calls the parts shells, usually in the US, we call them bearings)
                        At any rate... google or read up on using a stretch gauge to get the exact and proper torque accomplished for rod bolts. It is a rare opportunity to use a stretch gauge since both sides of the bolt are accessible, and move away from any possibility of difference in friction due to contamination, oil selection etc when you use the gauge to put in the bolts for con rods. Those variables can affect the end result vs actually getting the stretch right.
                        Just a thought. (otherwise, carry on. BTW con rod bolts are often available from affordable places other than BMW specific vendors, and I got my very decent stretch gauge from Jeg's of all places)
                        Alex.
                        Trying to make the world a better place, 6 TB at a time.
                        http://abloriginalparts.com/
                        • Garageaholic
                          • Dec 2005
                          • 5204
                          #57
                          Updates 6/3
                          some updates today: Got the drivetrain in today. First test fit of 3
                          First Fit 6/3: Analyze interferences or close contact. Begin measuring for headers. Mark parts of body that need further modifications.
                          Midterm: Make all body modifications, refine/complete headers
                          Second Fit (Late June): Late June: Crank Engine with electronics fit. Complete Headers and begin downpipes, midpipes, and muffler. Accessories Test Fit - Oil Cooler Lines, Power Steering, Compressor Test Fit, Radiator, Intake Test Fit. Heater CorePipes
                          Midterm: Organize electronics, pedal assembly Test Fit the core support. re-Paint Engine Bay
                          Third/Final Fit (Late July): Aesthetics, Final Exhaust, Body, Drive.
                          That's all I can think of right now.
                          It took me over 2 hours to get this to settle in where I wanted it . It's really far back, so I need to make further modifications to the firewall, even though I had the M60 in the car before. This engine is noticeably larger with all the extra sensors, pumps, and that HUGE intake manifold.
                          Got the ECU back from Adem Ergen at Ergen Motorsports. Thanks!!! He's been a great resource for random help throughout the swap.
                          And here is a to-do list. This is before I test fit the engine this evening. This list will likely double with all of the little tasks I have to get this engine to sit nice and snug in the engine bay.
                          I'll have more updates tomorrow!
                          Recent Rebranding!!
                          E30 SM62/S62
                          E30 M60 V8
                          E30 M30 Big 6!
                          • Jean
                            • 18228
                            #58
                            What a monster this will be! Good job man! Any ideas on the weight difference between the s62 and m60?
                            • MJCRO
                              • Apr 2012
                              • 597
                              #59
                              Looks awesome Frank! Slowly but surely man.
                              • george graves
                                • 20003
                                #60
                                Frank - you are the man......
                                btw - all your pictures are missing from your m60 swap thread ;(
                                Originally posted by Matt-B
