Extending a driveshaft?
  • MJCRO
    • Apr 2012
    • 597
    So I got the 87' 325e/es driveshaft for my M60 swap since I'm using a 5 speed ZF. I'm short 1.5" in length with the guibo attached. My motor is in rear position using Garagistic's mounts. According to other people using the 5 speed, wasn't the large output flange eta driveshaft supposed to be a plug and play part?
    Anyways, does anyone have any information on possibly extending a driveshaft? Maybe with longer bolts in combination with washers possibly? I've been searching in the tri-state for driveline specialists, could a cut and re-weld work?
  • alco
    • Feb 2013
    • 197
    Do not under any circumstance use longer bolts and washers. That is a recipe for disaster. Source an E36 328 (stick shift) drive shaft. Also note that the driveshaft is meant to extend, if yours is fully compressed you need to pull it out a bit.
    Velocity Motor Works
    1972 2002
    1983 533is
    1987 325is (Roxanne)
    1988 M6
    1989 M3
    1989 325ix (Darth Maul)
    Gone: 1974 2002, 1984 318i , 1985 318i, 1988 325ix Sedan, 1988 325ix Coupe, 1991 318is, 1991 318i, 1994 525iT, 1995 325is, 1996 M3 Coupe, 1997 328is, 2001 325i, 2001 Z3 2.5i, 2001 330i, 2001 525iT, 2006 F-250 SD and more...
    • iansane
      • 1341
      I'm not sure I'd trust even an "extended" driveline that had an extension welded on. I had to have an aluminum shaft extended a couple years ago and a local place, Drivelines Northwest just cut off the whole shaft, reused the yokes and basically made a new shaft to my length spec. Expensive, yes. But more more confidence inspiring.
      84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
      • Vtec?lol
        • Dec 2009
        • 3278
        the drive shafts slip yoke should extend 2.5" or 3"
        Take the collar nut off the rear half and remove the little bushing inside. Spray it with lithium grease and put it under the car and re-check fitment. If the teeth are deep enough in there then reinstall the collar nut and you should be good to go.
        • MJCRO
          • Apr 2012
          • 597
          Thanks guys, yeah I assumed extending it physically wouldn't make any sense, just wondered of the possibility. I'm a noob with driveshaft fittings, but I'll check out that slip yoke @vtec and come back with results. It's such a little distance, I hope this works
          • MJCRO
            • Apr 2012
            • 597
            Here's a picture of mine. So when unscrewing the nut, is it just the normal lefty loosey? There's also a c-clamp on the end of the nut, holding the bushing in place I assume. Do I need to remove the clamp before the unscrewing the nut? This thing is on tight, I need to find a bigger wrench since my vice grips are just sliding off from the paint.
            Also a picture from another forum.
            • Vtec?lol
              • Dec 2009
              • 3278
              yeah you've got plenty of adjustibility
              it's regular old lefty loose
              Use a pipe wrench on the flat hex part of the nut so you don't mar it up to bad and bent it. There's no c-clamp or anything else. Just loosen it up and stretch the shafts apart.
              • MJCRO
                • Apr 2012
                • 597
                Sweet, thanks vtec! Gonna try it out later tonight.
                • MJCRO
                  • Apr 2012
                  • 597
                  Just mounted it up. So slap a crap load of lithium grease on it and call it a day? I'm about 1.5" out to what I needed for it to fit, totally in love with this trick.
                  • Vtec?lol
                    • Dec 2009
                    • 3278
                    Sweet! Did you measure and make sure you have enough length for the teeth to slide in? I would mark them and check to see.
