For those using the manual brake setups, what are you using for the clutch master cylinder? Bore size is what I am looking for. How does your pedal feel compared to stock? Have you noticed any issues with return? Are you using a return spring?
Manual Master Cylinders Question
Velocity Motor Works
1972 2002
1983 533is
1987 325is (Roxanne)
1988 M6
1989 M3
1989 325ix (Darth Maul)
Gone: 1974 2002, 1984 318i , 1985 318i, 1988 325ix Sedan, 1988 325ix Coupe, 1991 318is, 1991 318i, 1994 525iT, 1995 325is, 1996 M3 Coupe, 1997 328is, 2001 325i, 2001 Z3 2.5i, 2001 330i, 2001 525iT, 2006 F-250 SD and more...Tags: None -
I'm using a stock 325 master cylinder. No idea what bore size is, look it up for a '87 eta. Pedal is a bit more stiff, but definitely reasonable (I've got the Massive kit). The cool part is that you have to put a MASSIVE amount of pressure on the brake pedal to take the brakes from 90% power to locking them up... which is a good thing i guess.
I'd say braking power was slightly reduced though... might want to look into a BBK (I currently am)
The master cylinders have pretty hefty springs inside of them... self returning. Also, the seals on caliper pistons are square cut for this reason as well. Don't get me wrong, it's not going to hurt anything if you decide to use a return spring, but you don't necessarily need one. -
Thanks guys.sigpic
1972 2002
1983 533is
1988 M6
1989 M3
Gone: 1974 2002, 1984 318i , 1985 318i, 1988 325ix Sedan, 1988 325ix Coupe, 1991 318is, 1991 318i, 1994 525iT, 1995 325is, 1996 M3 Coupe, 1997 328is, 2001 325i, 2001 Z3 2.5i, 2001 330i, 2001 525iT, 2006 F-250 SD and more...Comment
MJCRO are you using the 530's slave cylinder or an E36 part?sigpic
1972 2002
1983 533is
1988 M6
1989 M3
Lol, I don't think wilwood really makes parts for specific cars... their stuff is pretty universal :)
Pedal feel is better than stock, while effort is actually pretty close with the 6.2:1 pedal box and 5/8 cylinders. Flat spotted 3 tyres so far it's that good (old tyres).Just a little project im working on
- http://www.lse30.com -Comment
The question to MJCRO was specifically about the OEM slave cylinder on the transmissions not the master that will be at the pedal.Lol, I don't think wilwood really makes parts for specific cars... their stuff is pretty universal :)
http://www.wilwood.com/MasterCylinde...inderList.aspxsigpic
1972 2002
1983 533is
1988 M6
1989 M3
Excellent, I'm much closer to having all of the bits and pieces...good things to come.sigpic
1972 2002
1983 533is
1988 M6
1989 M3
