5.0 swap brake booster set-up
  • a vvhiteman
    • May 2013
    • 30
    This question has been asked and answered many times I'm sure, can't find the exact answer I was looking for. I've seen a few builds and it looks as though some people are able to keep the brake booster in the same location as stock? Is this a stock brake booster or one from another model? I have seen the brake booster moved into the stock abs location. Just trying to see the options that have worked for people. Thanks in advance.
  • jalopi
    • 2370
    I've heard of people using geo metro boosters or something like that without hitting the valve cover, but never seen it in person. To be honest, I'm not really sure it would work with every setup.. e30v8's mounts aren't exactly "machine made" in the sense that they're not all made the same.
    Skip the booster idea unless you plan on doing the remote 540 booster setup or a hydroboost setup. If you plan on ditching the brakes, do not, I repeat DO NOT do what e30v8 recommends and buy that wilwood pedal set. Trying to use it with the stock brake pedal is a real pain in the ass. Instead do a pedal box and you'll be much happier.
