*Updated & only kinda shitty now!* The definitive 5.0/302 swap guide
:up:
Originally bought the 165 when I was going to keep it a 302 came into some more $$$$ and changed plans. Defiantly Keeping it under 6k building it for torque. If I get 350hp ill be happy, should have no problem getting that. My stang makes that with a ford racing letter cam and gt40X heads. Guys are running the same cam and heads any getting in the 400hp range with an RPM intake and 650-750 carb.
$hit canned my 2.5" Y pipe tonight for my new cobbled together 2.5" repurposed mustang off road X pipe. Makes a big difference in power and got rid of the raspy rice burner sound I was getting at high rpm's
Wish I could post pictures...Last edited by tokoloshe; 12-21-2014, 08:39 AM.Comment
I've decided I'm going to get Fordstrokers to build me one.sigpicComment
Yep, that's the conclusion I've come to as well. Have you watched any of his videos on sbfbuilding? Jim seems to know his shit.
I realize they're expensive as hell, but aside from our stories (which I'm pretty sure were because we were rocking unbaffled front sumps cut down to 4qts) you rarely hear about ford guys having oil starvation issues [with one of those fancy canton road race pans anyway], which is why I refuse to spend big money on a LS.... don't feel like drysumping to eliminate a problem from the factory. Throw in an accusump and I'm pretty sure I'll be gold with my proposed setup
Thing is though, can't decide which block I wanna go with. Either a big bore 347 or the 'fuck your four cylinder' 363. Not sure which'd be better / last longer since I plan on using it at 6k rpms for extended periods of time. Or if the extra cubes'll really make a difference with the turbo or notComment
So are you going aftermarket block? Ballin! I don't think more cubes is ever bad, even with a turbo.
The Accusump should help you a ton. Mine served me well until this last time, obviously. After draining the oil, and having plenty there, the only thing I can conclude is oil didn't drain back fast enough. I'm going to add two external drain lines from the heads, and further work on my pan as much as I can. I do not want to hurt this next engine! I wish a dry sump were cheaper and easier to do, that would solve so many problems.sigpicComment
yeah, figure i can't get into the big boy power levels required in proam without a dart block. not to say i'm anywhere near that good a driver, but it'd be nice to have the equipment to serve me, if necessary.
what kind of accusump valve were you rocking? apparently the non-epc ones release kinda slow. also, don't know if you have/had this on your last setup, but i plan on grounding the accusump valve out through a dummy light in the dash. figure that way i'll know if it's on or not
interesting idea on the external oil drains. did a little bit of reading on that (to see a visual representation), saw a few of dudes mentioning putting a drain in the lifter valley too, though i think it was for a 351 block, not sure how'd that work on the 302
as far as stroke choice goes, i'm a bit concerned about the rod ratio/piston compression height of the 363. it's something like 1.55 rod ratio and a compression height of 1.1" or so. 3.25" stroke is 1.66 rod ratio and i think a 1.2" compression height. theoretically better for RPMsComment
their standard electrics are fairly inefficient, but their "epc" valves are (from what they claim anyway) pretty ideal since they open/close based off of oil pressure. the idea is that their sensor will see a drop in pressure and open the valve & get pressures up to a reasonable level before you even notice the drop
toko, as long as you're streeting the car you don't really need a kickout, though i guess it wouldn't hurt. mine only took a shit after thrashing it on track for probably (combined) an hour and a half drifting. i'm guessing an oil cooler might've helped keep that from happeningComment
The manual valve is open all the time, so it's constantly equalizing pressures. Before this last trip to the track, I never saw oil pressures waiver by more than 5 psi. I'm going to stick with it, except add a remote cable so I can operate it from inside the car.sigpicComment
here's the difference between the manual valves and the electric ones - if you've got, for instance, a 25-30psi valve on the accusump, it'll hold at 30psi
the difference being that the manual valve unit will release oil pressure at a constant rate, not when the engine necessarily needs it. you can drop to 30 psi, but the epc one won't open. as soon as the pressure drops below 25psi, the epc accusump will slam the oil passages with 30psi (or whatever the highest figure was) of oil pressure, not a gradual trickle that'd result from leading up to a bearing failure. at least that's the way i've taken it anywayComment
You just said LS's and Fords have the same problem.I realize they're expensive as hell, but aside from our stories (which I'm pretty sure were because we were rocking unbaffled front sumps cut down to 4qts) you rarely hear about ford guys having oil starvation issues [with one of those fancy canton road race pans anyway], which is why I refuse to spend big money on a LS.... don't feel like drysumping to eliminate a problem from the factory.
People with modified oil pans and reduced capacity have problems on both LS and SBF sides of the fence, people with fancy road race oil pans don't have problems on either side of the fence.
Not proposing you switch... just saying posts should make sense.Comment
