My M60 swap
  • Jack89i
    • Dec 2013
    • 240
    My M60 swap
    I've had my e30 for a about 3 years now and I've decided it's time for 8 cylinders..
    Sent from my iPhone using Tapatalk - now Free
    sigpic'89 325i
    M60 swap in progress
  • Jack89i
    • Dec 2013
    • 240
    Here's the car I pulled the engine from
    sigpic'89 325i
    • DDF_Dutchie
      • Aug 2012
      • 22
      You're E30 looks great!
      What are you're plans exactly for your swap? (Drivetrain, Brakes,Ground control etc.)
      Goodluck
      • Zacm829
        • Jan 2008
        • 1919
        Looking good, saw your post on facebook. Curious as to what you do for braking and transmisson. Good luck!
        1987 325i-M60b44 swap
        • Jack89i
          • Dec 2013
          • 240
          Thanks! I'll be using the five speed and I haven't decided on brakes yet.. A full wilwood booster less setup is like $500..I don't really know how to weld for a booster relocation so we'll see.
          Got the engine in my garage and pulled the valve covers off. Wasn't too dirty under there
          I had a small scare when I pulled the spark plugs out and one had a bunch of water on it but it was just water sitting down in the well
          sigpic'89 325i
          • CorvallisBMW
            Long Schlong Longhammer
            • 13039
            Sweet! sub'd
            • jalopi
              • 2370
              Are you doing a full tear down of the engine, or just basic stuff?
              • Jack89i
                • Dec 2013
                • 240
                Just a basic tune up and gaskets
                Took the valve covers to my highschool autoshop today and cleaned/wire wheeled them best I could for paint
                sigpic'89 325i
                • dirty30
                  • 3010
                  We talked a little at the Vintage last year, glad to see you went for the M60! You will not regret it. PM me if you run into any trouble.
                  • Jack89i
                    • Dec 2013
                    • 240
                    Good to hear from you! I will definitely be PMing you as I have lots of questions about plumbing and brakes/I'm sure I will run into trouble..
                    sigpic'89 325i
                    • Jack89i
                      • Dec 2013
                      • 240
                      Tonight I started taking things apart.
                      Not the cleanest in there..
                      I will need to find a new wiring harness because when I was pulling this engine I got a little frustrated and just cut the old one
                      sigpic'89 325i
                      • alco
                        • Feb 2013
                        • 197
                        I might have a spare wiring harness. Also if you are looking for a remote booster setup, I have an entire setup with some odds and ends spares (rods, brackets etc) that I'd let go for about $250 shipped.
                        Velocity Motor Works
                        1972 2002
                        1983 533is
                        1987 325is (Roxanne)
                        1988 M6
                        1989 M3
                        1989 325ix (Darth Maul)
                        Gone: 1974 2002, 1984 318i , 1985 318i, 1988 325ix Sedan, 1988 325ix Coupe, 1991 318is, 1991 318i, 1994 525iT, 1995 325is, 1996 M3 Coupe, 1997 328is, 2001 325i, 2001 Z3 2.5i, 2001 330i, 2001 525iT, 2006 F-250 SD and more...
                        • Jack89i
                          • Dec 2013
                          • 240
                          Hit me up if you find a spare harness. I'll probably get the brake setup from my donor car if I don't get a wilwood setup
                          sigpic'89 325i
                          • alco
                            • Feb 2013
                            • 197
                            Which harness are you looking for specifically? I have a couple here...
                            1972 2002
                            1983 533is
                            1988 M6
                            1989 M3
                            • Jack89i
                              • Dec 2013
                              • 240
                              OBDI with everything
                              sigpic'89 325i
