Originally posted by CLM21
View Post
There are things missing from the garret swap guide/kit you'll probably want to do to finish off the car to your standard, not just try to get it in there pretty cheap. There is a lot of DIY stuff in the guide that makes it seem easy/cheap if you have the ability and equipment to do it all yourself, otherwise you would be better off buying one of their (or others) kits.
Add up a quick list of things.
Swap/kit components (mounts, etc)
Engine
Transmission
Clutch
Tailshaft
Sump
Differential / Rear End
Electrics
Cooling
Fuel system
Then if you start replacing components that look worn/old or fixing the few short comings LS1 motors have that see them die. Plus you have things like brake upgrades, gauges, fittings, lines, fluids, etc.
If I did this on the ultra cheap I still reckon it would cost me $10,000. If you are going all out and using new parts, especially if you spend time on the headers, upgrade the valvetrain or fit some new bits, I reckon your realistic budget all said and done would be closer to 15k than 10k.
