I'm either getting old, my vision is going or I'm just not looking in the right place for I just can't seems to find the right info on a <88 European E30. I have a Euro 85 323i with the square c101 so I figure I better ask before I end up frying a harness.
I've done the obvious connection from the M60 to square c101 and I can fire up the engine and start it.
The wires I have left from the square 101 is the BL/WT pin 17(service indicator reset) and the BLK/BR pin 16(oil service). I have no clue were to connect them.
The engine coolant wires-I see one of them matches BR/VL pin 4 to pin 12 on the M60. there is also a second coolant wire (pin 11)that is ground from the m60 so I assume to just ground this wire by the fuse box. as for the the tack wire I see I have to get the oem bmw 4 cyl coding module and then the RPM module from garagistic.
Thank you for the help...........enjoy the 4th July !!!!!!!!!!:razz:
