404 ecu
    404 ecu
    The correct ECU to use for an m60swap WITHOUT EWS is a black label ECU with the number ending in 404, correct?
    Have you made a purchase from www.blunttech.com recently?
    sigpic<< wrecked
    Actually, I think it's more of a blue, but yes, 404 is correct.
    I'm told that the 530 and 540 ECU is different, and you have to have the appropriate chip for the displacement of your M60, but even the BMW part # is the same between the two.
      Thanks mr slam
      sigpic<< wrecked
        yes both have 404,you have to check engine displacement by vin code on the ecu
