Hey guys, new to the forum, just picked up a 89 325i. It has higher miles (odometer stopped at 232k), and once the motor goes out on this thing im gonna do a LS swap into it. In the meantime i am going to go ahead and start gather parts for it. Gonna go ahead and apologize if I have to ask about some e30 specific terminology. Never owned an e30, or even a car for that matter. Always been a truck and jeep guy.
To start, my e30 is lowered, and im just not one for the lowered look, and it j wont work with my parents driveway, as i scrape pretty bad going up it. I want to go ahead and get some new springs for it and have it sitting as close to stock ride height as possible. Since the LS is so much heavier than the current 2.5, did any of you upgrade springs and other suspension stuff, and to what? If I do need to get stiffer/stronger front springs, would it be a good idea to go ahead and run those before the swap? I wouldnt care if it made it sit up higher, if that would be the only real problem with it.
I have also started to look around for motor and transmission. I was looking, into the LM7 since they are cheap and easy to find. Or would it be worth searching for a L33, since it has the aluminum block? Not sure what the exact weight difference is. I have read that the T56 is a popular tranny to put into it. Anyone run the T5 with any luck? If I find a T5 from an F-body camaro does the shifter line up with the stock hole still? And i know it wont be nearly as much fun, but what about an auto tranny, anyone done it and liked it?
One last question: tires. any need for a stiffer load rated tire? Going to order tires this week, and need to know since these tires will still be on when i do the swap. Also, any tire recommendations are welcome.
Thanks for any help!
