How many of you have gone boosterless? Pros? Cons? dd
  • MT325is
    • May 2012
    • 1103
    Like the title says..
    i dont know which one to go with. The car will just be a cruiser since its a vert.. not always a dd..
    Any input would be greatly appreciated
    1989 BMW 325is (SOLD)
    1992 BMW 325IC (SOLD)
    1991 BMW 318IS (STOLEN!)
    2017 BMW M2 (WEEKEND WARRIOR)
    1989 BMW 325IC (PROJECT(
    2002 FORD ESCAPE (DAILY)
  • e30s50dan
    • Nov 2008
    • 2076
    :popcorn:
    NASA
    BMWCCA member
    PCA member 25yrs
    1991 318IS slick top
    1997 M3 sedan
    2001 325CI DD
    “whoever turns the wheel the least, wins"
    • ThatOneEuroE30
      • Dec 2013
      • 8626
      Wondered the same except my car will see track time on the occasion
      1991 318i 4dr slick top
      Mtech 2 turbo restoration
      • Chris916
        • 183
        My racecar is boosterless. Best mod I've done for a track car. It takes a good amount of effort to brake hard, but you can get more aggressive with the pads without worrying about locking up. I pretty much stand on the brakes.
        With a proper master cylinder setup though it should still be streetable.
        • Gertech
          • Jul 2013
          • 180
          I ran mine boosterless with stock brakes and stock master for a while, just modified the pedal ratio. I used Massive's kit. With the stock brakes it stopped but required a lot of effort and wasn't ideal for street driving and panic stop situations. I recently upgraded the front brakes to Ireland's 310mm Wilwood kit though and it made a huge difference. Less pedal effort, great bite. No longer feeling like I need to go hydroboost.
          • csm-e30
            • Oct 2014
            • 95
            I have a set of wilwood 5/8 MC's coming with the Wilwood pedal set suggested by Garagistic. I will let you know soon how well it matches up. I chose this route because of my extremely limited fab experience.
            • jalopi
              • 2370
              i don't know why anyone would purposely remove their power brakes if they didn't need to... hell, it's one of the reasons I'm switching to a bigger chassis (so I can have my cake [v8] and eat it too[working brakes])
              i had the massive kit with a 5/8 master, 330i brakes on all 4 corners, hawk hps pads. before i put the bigger brakes on my car would barely stop. pretty much had to do a one legged squat on the pedal to get it to stop. the bbk setup basically put me back to stock feeling brakes
              seriously man, it takes an additional couple grand in BBK stuff (all 4 corners) just to get back to the level of braking force that you had with the booster... only do it if you can't keep the booster, you will hate life.
              • Stvstr
                • Dec 2013
                • 82
                My e30 5.0 swap has the Massive booster delete, stock brakes and a 5/8" m/c and the brakes require way too much leg power to emergency brake. It may be ok on the track but it's not appropriate for street.
                • bmk
                  • Feb 2011
                  • 598
                  100% agreed. Its fine for just dd but emergency braking is very sketchy!
                  Worlds 1st LS powered e30 cabby.
                  Cab
                  billac: 92 Lagunengrün cabriolet + cadillac LQ9 + Nitrous + rotiform SJC
                  Raphael: 88 Lagunengrün IX + Hella 500's + Red ACS type 1's
                  Shaggin Wagon
                  : 01 325xiT 5 speed
                  91 MR2 GT3076TS + E85 = 505whp + antilag = wheelies
                  88 CRX OEM+ 42mpg DD.
                  • e30s50dan
                    • Nov 2008
                    • 2076
                    What is your brake setup..big brakes? What pads? Thanks. Building a m60 e30 race car only also
                    NASA
                    BMWCCA member
                    PCA member 25yrs
                    1997 M3 sedan
                    2001 325CI DD
                    • dirty30
                      • 3098
                      I run boosterless with M coupe brakes front/ rear 5/8ths master cylinders with a slight rear bias. I run a performance street pad (maybe axxis ultimates?... its been a while)Setup has worked really great and has plenty of stopping power.
                      • shiboujin
                        • Feb 2006
                        • 2791
                        Expensive but man it feels like factory. This is what I got. factory everything else.
                        • kevinbednarek
                          • May 2012
                          • 35
                          I run a Wilwood pedalbox with dual 5/8 masters running stock brakes with my M62 swap. I also used the Garagistic mount. If I were to do it again, I'd probably go with a hydroboost setup. The brake pedal wasn't adjusted correctly on the pedal box before I installed it (my fault) and it's a real bitch to take it out again.
                          If it were adjusted properly and I had bigger brakes or even better stock sized brakes, it really wouldn't be that bad. Emergency stopping gets hairy (ask me how I know) but you can adjust your driving style to avoid those situations.
                          • eurotrash
                            • May 2007
                            • 768
                            Peddle is a brick but once i got used to it i actually liked it more. Prob a bit much for dd stop and go traffic tho.
