e30 5.0 swap drive shaft
  • danval
    • Mar 2013
    • 191
    Ok you guys, im trying to do some research on 5.0 driveshfts. Post some pics and info on your modified shafts and insight on what could have been done different or better. Also, where in socal can I take mine to get done? Thanks in advance
  • e30_302
    • Sep 2013
    • 453
    Get an aluminum shaft from a cop crown vic off ebay. I got mine for $100 shipped and had it shortened for $60. Weighs almost nothing.
    • danval
      • Mar 2013
      • 191
      Same imput shaft on the t5 side? And how would I convert the tail to bmw diff if its aluminum?
      • e30_302
        • Sep 2013
        • 453
        You'll need the correct slip yoke for a T5, and a u-joint to take care of the trans end. Diff end you'll need the flange from www.jagsthatrun.com and another u-joint. Pretty simple.
        • danval
          • Mar 2013
          • 191
          Got any pix of yours?
          • e30_302
            • Sep 2013
            • 453
            I'll get some this weekend.
            • danval
              • Mar 2013
              • 191
              Thanks brotha
              • e30_302
                • Sep 2013
                • 453
                Hey didn't get a chance to get any pictures- I'll try next weekend (by the time I get home in the evenings during the week it's dark). It's really straight forward though, definitely one of the easiest parts of the swap.
                • IronFreak
                  • Dec 2012
                  • 3702
                  thought I'd toss this in here. Haven;t used it personally, but I know funfgan, balski and a few other 302 swap guys used it.
                  Spicer 2-2-1679, Our Price: $155.80, Normally drop ships the same, or next business day. Flange Yoke, 1310 series, 4xØ.406 Holes on 3.344BC, Ø1.812M pilot
                  Instagram @rebellionforge
                  • danval
                    • Mar 2013
                    • 191
                    For sure, I would like to see the final product.
                    • danval
                      • Mar 2013
                      • 191
                      http://www.northerndrivetrain.com/pr...-2-2-1679.html
                      Nice! Is it a straight bolt on to both sides of the sections? Besides modifying length of course.
                      • thedivision
                        • 42
                        From Jags That Run:
                        "We use the Spicer Toyota flange for the BMW, however, after cleaning the flange, we press fit a micro sleeve (about .0195" wall thickness) onto the pilot, and use locktite to make sure it stays in place.
                        Also, the pilot is too long to fit properly onto the BMW differential, so we also machine the pilot to the correct height."
                        • The Dark Side of Will
                          • Jun 2010
                          • 2796
                          Originally posted by thedivision
                          From Jags That Run:
                          Interesting...
                          Is this on the web someplace or in an email?
                          • thedivision
                            • 42
                            Originally posted by The Dark Side of Will
                            Interesting...
                            • IronFreak
                              • Dec 2012
                              • 3702
                              I can't speak for the trans side but I'm almost positive this bolts right up to the diff flange. At least covers one side for you.
