wondering what throttle cables everone is using with the LS swaps. so i can order one sooner then later...
what throttle cable are the LS swaps using?
91 e30 318is M50 SOLD
http://www.r3vlimited.com/board/showthread.php?t=149570
92 325 vert project
http://www.r3vlimited.com/board/showthread.php?t=341370Tags: None -
I went to the junk yard found one about the length i needed spliced the stock one so i could use the OEM fitting on the pedal done. Cost me $3 and an hour of time. However since your in canada you could just order online http://www.summitracing.com/parts/lo...ht36/overview/Worlds 1st LS powered e30 cabby.
Cabbillac: 92 LagunengrĂ¼n cabriolet + cadillac LQ9 + Nitrous + rotiform SJC
Raphael: 88 LagunengrĂ¼n IX + Hella 500's + Red ACS type 1's
Shaggin Wagon: 01 325xiT 5 speed
91 MR2 GT3076TS + E85 = 505whp + antilag = wheelies
88 CRX OEM+ 42mpg DD. -
Originally posted by matt kingI used the lokar tc-1000ls1 36". Perfect fit for me.
great ill order that.
thanks.91 e30 318is M50 SOLD
92 325 vert project
http://www.r3vlimited.com/board/showthread.php?t=341370Comment
How's the length and pedal fitment with that 36" lokar cable?Alpine White 1989 E30 Coupe - LS1/T56Comment
nice mine should be here this week... hope to drop motor n trans in next weekend waiting on my slave cly fittingsOriginally posted by matt kingIt connects to the pedal perfectly.
I had to use two large diameter washers to lock it to the firewall
I painted those black.
Honestly if there was a 40" or so length it would look better
It has the length as is. But it runs a little diagonal across the motor.
It comes with the correct connector to attach directly to the throttle body91 e30 318is M50 SOLD
92 325 vert project
