What is your swap weight all V8's welcome
  • bmk
    • Feb 2011
    • 598
    What going on guys wanted to start a thread to see what everyone's V8's swaps are weighing in at. Please include as much detail as you can on it.
    I havent weighed mine due to fear...
    With everything I got on my car im guessing the it weighs around 3200. I think I may permanently remove the top and just use the hard top when I need it. My ideal weight would be 2800 I dont think I have a chance at that tho
    Worlds 1st LS powered e30 cabby.
    Cab
    billac: 92 LagunengrĂ¼n cabriolet + cadillac LQ9 + Nitrous + rotiform SJC
    Raphael: 88 LagunengrĂ¼n IX + Hella 500's + Red ACS type 1's
    Shaggin Wagon
    : 01 325xiT 5 speed
    91 MR2 GT3076TS + E85 = 505whp + antilag = wheelies
    88 CRX OEM+ 42mpg DD.
  • Q8y_drifter
    • Aug 2009
    • 297
    My donor E30 is a base model 316i with pretty much everything gutted. I'm really interested to see how light I can get it with a LS1 + T56.
    Alpine White 1989 E30 Coupe - LS1/T56
    • midnytegsedan
      • May 2012
      • 38
      88 vert with soon to be lq9 motor and ss trailblazer auto tranny with shift kit. I heard the swap was only a few hundred pounds more than factory. 250 maybe?
      03 infiniti G35 sedan
      90 325i vert
      • garretvs
        • 464
        Our E30 with M20 manufacturer weight is 2778lbs. With LS1 and T56, it weighed 2870 lbs with 1/2 tank of gas and no driver. 4-corner scales gave weights of 795/800 front and 620/655 rear.
        The weight gain was about as much as having a 12-year old in the front passenger seat. With 350 hp and 350lbft torque (300 at 1600rpm!!) the extra weight is invisible.
        E30-LS1 aka. 357is
        email us to pick up our LS1 swap guide
        E30-LS1 KITS now available!!
        E30LS1@gmail.com
        e30ls1.com
        • bmk
          • Feb 2011
          • 598
          Unless your running against something that is actually fast....
          Cab
          Shaggin Wagon
          : 01 325xiT 5 speed
          • gobuffs
            • Dec 2004
            • 513
            E30 M3 race car ready to race with S65...around 2800. Heavy.
            • 1990m3
              • 1180
              hate to say it but I agree, heavy. Would be nice to have it closer to 2650. How much does the S65 weigh compared to an LSx?
              • MonkeyMadness
                • 3251
                I have a completely stock 91 318is. with an M62 with 5spd.
                no AC, no PS, no ABS
                Car feels super light when on jacks and while driven. would be surprised if it was much heavier than the Iron block M20 cars.
                I think I read on this site that the weight diffrence between the M60/5spd and the M20/5spd was 40lbs? hoping that's true.
                • gobuffs
                  • Dec 2004
                  • 513
                  No idea. I should say...the 2800 ready to race, it with my big ass in the driver's seat. Without me it is closer to 2500.
                  • iflytii
                    • Jun 2004
                    • 482
                    I was around 2350-2400 with my LS swapped racecar so I would guess you are 2500-2550. I don't know that your motor is a lot heavier than my LS but that transmission was a beast.
                    • gobuffs
                      • Dec 2004
                      • 513
                      The S65 with stock FW and tranny is 120# more than the S54 with lightweight FW and 5 speed.
                      • jalopi
                        • 2370
                        i'm sure most of you have seen this thread by now, but my 302 weighed in around 380-400lbs with a carb, aluminum heads and no AC/smog.
                        so...
                        Ford 302, stock - 480lbs (with AC [guessing 12ish lbs], smog pump[guessing 12ish lbs], EFI intake [20lbs heavier than a carb intake + carb. you can still get EFI intakes that look like carb intakes for weight reduction purposes], iron heads [18lb difference per head])
                        LS aluminum block, stock - 480lbs (subtracted 120lbs for the t56)
                        We weighed our LS1-T56 with engine mounts, intake manifold, A/C, PS pump, water pump, alternator and wire harness on 3 bathroom scales. Weights came out at about 260lbs at each engine mount and 84lbs at the transmission mount. Total was 604lbs.
                        LS iron block, stock - 590lbs
                        Pictured, aluminum LS bare block on a scale (interestingly the same weight as an OE SBF block)
                        Pictured, iron LS bare block on a scale
                        anyone got ACTUAL weight figures for a m60?
                        • Kevinl
                          • Oct 2012
                          • 897
                          The reason a LS engine weighs so much more than a 302 is because it is not a piece of shit
                          1989 BMW 325is Lachsilber metallic 5 speed
                          2007 BMW 335i KARMESINROT 6 Speed manual
                          2011 BMW X5 35I
                          • jalopi
                            • 2370
                            oh my... and all this time i figured the bloated weight was to match the owners' overestimated power claims
                            #shotsfired
                            • MonkeyMadness
                              • 3251
                              #shotsfired
                              :popcorn:
