Sikky LS1 swap - shifter hole issues
  • Q8y_drifter
    • Aug 2009
    • 297
    Anyone here have pics of their shifter / shifter hole alignment using this kit? I dropped in the engine/trans yesterday (LS1 + F-Body T56) the shifter is currently sitting about 2-3" back from the centerline of the hole and I can't for the life of me figure out why that is. Haven't yet installed the driveshaft to confirm fitment as I ran out of time. Will do that tomorrow prolly.
    Alpine White 1989 E30 Coupe - LS1/T56
  • shiboujin
    • Feb 2006
    • 2791
    Mine sits forward in the hole. I think mine is the Camaro F body style shifter but it's MGW with it setup to place the shifter farther back by an inch. Got pix?
    Edit: I think I have the GTO shifter and the MGW setting it forward actually. Here's the best pic I got:
    • Q8y_drifter
      • Aug 2009
      • 297
      My shifter is also an MGW unit. However, even with the orange block and stick removed, the center of the shifter does not line up with the hole. Pic below (also note the shifter hole on my E30 is a bit ovalish opening up towards the rear - shitty body work)
      Pic below
      • shiboujin
        • Feb 2006
        • 2791
        Is most of that sheet metal stock? That looks odd. I'll check with my other LS buddy. It looks like if you cut it a bit and use the MGW extension to put it forward, it'll sit about right.
        • shiboujin
          • Feb 2006
          • 2791
          Here's another guy with just a fox body setup.
          • Rocknrollcows
            • Jun 2013
            • 31
            Yoshi means Fbody, not fox.
            But I cut the shifter hole to fit, it allows allows extremely easy fluid changes and changing shifters.
            Edit:
            In regards to the above photos, the stock fbody shift handle did not fit. I used a pro 5.0 shift arm that tilted the shifter forward some. I'm now using a 5" Hurst extension. Can take pics later
            "stock motor"
            • Q8y_drifter
              • Aug 2009
              • 297
              Was the shifter stick lined up with the hole prior to cutting?
              Thanks
              • shiboujin
                • Feb 2006
                • 2791
                looks about as lined up as yours does.
