anyone has some tutorial how to do it? some pics? it will help a much
HELP with CPS bracket on 5speed tranny (M62 swap)
If you don't have the capability to fine tune the crank sensor offset in your DME, it's probably not a great idea.
I'm not sure if the M60 lower timing cover can install to an M62, but that's the direction I'd be looking.Comment
I've been very interested in knowing this, and so far I haven't come across an answer. Along a similar line, does the M60 pulley/crank wheel go right on the M62 without undue difficulty?Comment
Frank malacuso has a write up on how to do this in his m62/s62 swap manual for the 6 speed. You might send him an email.sigpic
Gigitty Gigitty!!!!
12 135i M sport cabrio grey/blackComment
You do not need to drill holes in the bell housing. you can but i have never seen anyone do it. the easiest rout is to swap over the front timing cover fron an m60 because it has the cps mounting bracket.
the only issue is the gap between the top covers and the bottom. some say you can seal the gap with rtv and it wont leak.
other methods are to cut the cps bracket off the m60 cover and weld it to the m62 cover. simple if you know someone who can tig weld.
or what monkeymadness did and i copied is to buy an m20 cps bracket. shorten it 5/8 of an inch. and have it re welded. now you have a bracket with two holes, all you need to do is tap the front cover and bolt the cps bracket on.M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28Comment
but then you must have dme from m60 engine. But i have everything from 2001 740iYou do not need to drill holes in the bell housing. you can but i have never seen anyone do it. the easiest rout is to swap over the front timing cover fron an m60 because it has the cps mounting bracket.
or what monkeymadness did and i copied is to buy an m20 cps bracket. shorten it 5/8 of an inch. and have it re welded. now you have a bracket with two holes, all you need to do is tap the front cover and bolt the cps bracket on.Comment
Yea that's true, I believe the cps must read the trigger wheel in the fly wheel. You could just extend the cps harness and drill a flush hole on the five speed if you wanted to keep it obd2
Sent from my LGLS740 using TapatalkM30 is God's motor.....but Jesus drives an M60'd car -slammin.e28Comment
Yes i want keep it obd2 but can't find tutorials or some writeups of this workComment
