Can anyone verify the Mishimoto radiator that I need for the LS swap? I believe i have seen that the 99-02 Z3 is what is needed but i wanted to verify that and see if anyone had pictures of one installed. Thanks!
MISHIMOTO radiator for E30 LS swap
I used a Mishimoto R32 GTR radiator for my swap. Required mounts to be fabricated but the width, height, thickness and inlet/outlet locations was perfect.Alpine White 1989 E30 Coupe - LS1/T56 -
Mishi is what is used for my 7.1L LS Swap, Just make sure you have a good SPAL fan on there95 7.1L 16V E36 M3
Motorsport Hardware ***Wheel studs and Spacers!!!--->FOR SALE 4/5 Lug Stud Conversion Kits available CLICK HERE
LIKE my Facebook Page! CLICK HERE
My Garage
09 Mini Cooper S (Daily)
09 E92 335i Msport
09 E70 X5 4.8
88 325es - Build Thread - http://www.r3vlimited.com/board/showthread.php?t=383423
87 325i m50 swap
87 325esComment
I used an RB25DET lower hose, a combination of 90 degree hoses and a coupe of aluminum hose joiners I got from Pegasus. Cut them to fit and currently working pretty good.
I do have a couple different hoses I wanna try out down the road though. If they fit, that should eliminate the need to different hoses and joiners. I'll keep you posted how it goes.Alpine White 1989 E30 Coupe - LS1/T56Comment
Please do, thanks! In the meantime, do you mind sharing some pix of the setup? It would help greatly!
Sent from my iPhone using TapatalkMy Garage
09 E92 335i Msport
09 E70 X5 4.8
87 325i m50 swap
87 325esComment
Some quick pics I got a few weeks back.
My radiator finally arrived. I ordered the Jegs variant of this same radiator however, it arrived damage so I returned and ordered the mishimoto r32 instead. I'll post pix once installed.
I'll post mounted pictures in my build thread. Thanks for the pix/help/advice Q8y_drifter
09 E92 335i Msport
09 E70 X5 4.8
87 325i m50 swap
87 325esComment
Did you guys plumb in a surge tank or did you just use the radiator cap and then plumb its vent to an overflow tank?
I was planning on following this diagram but the mishimoto radiator is different because it has a radiator cap, and technically no vent line, just the overflow line.
In the pictures posted by Q8y drifter you can see they have the vent running to the top of the water pump. I'm assuming it's a wp swap.Did you guys plumb in a surge tank or did you just use the radiator cap and then plumb its vent to an overflow tank?
My solution instead is to run a mishimoto coolant temp housing with a nipple fitting and plumb the vent to it like this dude did.
