Hallo Guys , i swap M62 B44 non vanos to my e36 , using the automatic harness , front cover from m60 , pulley from m60 , and CPS M62 2PIN , car starts and running good, but i think running in limp mode, rev limiter is in 3 or 4000 rpm ( i dont have connect rpm cluster ) i try disconnect a camshaft position sensor , try maf disconnect , O2 sensor is connect but maybe on wrong side , left is on the right , and right is on the left , but that will not put engine in limp mode ? maybe the ATM soft will make problems , after i pull out the engine from e38 i will everything change on manual with the BMW SCENNER ,
diagnostic errors : CAN TIMEOUT EGS
Tank ventilation valve output
and reference mark sensor ( but if engine running i will try disconect the camsft position s. but no difference )
i dont now what doing now , it need any pinout on ATM wiring ? please help me
( sorry for my english )
