M60 Auto Swap
  • JermMer
    • Apr 2016
    • 8
    M60 Auto Swap
    Looking for some info on a E30 M60 with a auto transmission..
    My plans are a M60B44 with 5HP18, 404 DME and loom with a M60B40 front timing case.
    Any reason why this will not work?
    Car is only being built as a Grunty cruiser not building for racing or drifting.
    Now I understand the 5HP30 is a bigger stronger box however they are know for their problems and the 5HP18 is a more reliable box.
    I'm aware that their is tunnel bashing required with the 5HP30 but I'm hoping to avoid this with the smaller 5HP18. I will probably use garagistic mounts and notch the sump to avoid the subframe spacers.
    If the 5HP18 destroys itself I will likely have a gearbox shop build a strong one.
    Has anyone done this combo before, can offer any advice on prop shafts ect?
    Cheers
  • DesertBMW
    • Aug 2011
    • 1042
    I did try fitting S50 with 5HP18 and it did not fit, and it looked like hammer would not work, part of a tunnel has to be cut out
    • The Dark Side of Will
      • Jun 2010
      • 2796
      The 5HP24 has a removable bellhousing. It *may* fit the 4HP22/24, allowing you to use the 4HP box with your M60B44. It's plenty strong enough, especially if built as a 24.
      • slum dog
        • Jun 2017
        • 110
        Aim also considering an auto swap
        So to do this ....what else needs to be done
        I assume I will have to get the ecu for the 4hp/22
        What about wiring?
        Thanks
          • Jun 2010
          • 2796
          You'll need wiring to connect the EGS (electronic gear selection) to the transmission.
          The best course of action would probably be to use an aftermarket controller in order to set the shift mapping up to match your engine and driving style. Since the 4HP's were never used with the M60's, the shift points and pressure control aren't going to be right for the engine's power band and torque.
          There were also non-electronic versions of the transmission, but tuning them requires getting oily.
          • slum dog
            • Jun 2017
            • 110
            I have spoken to our local aftermarket tuner before I stripped my 540i donor.
            I started getting the annoying trans program error on the cluster,
            It used to just come up randomly put the car in limp mode.
            I had a known bad battery in the car so I figured it must be that, cause I could just switch the car of and start up again with no problems for the day.
            There were also non-electronic versions of the transmission, tuning them requires getting oily.
            A little more info please regarding the above , looking to start my swap in October just preparing if my zf5hp30 looks into retirement.
            Thanks
