Flywheel and clutch compatibility question (m60)
  • FireFight
    • Mar 2012
    • 1367
    **updated question**
    Can i run a s62 flywheel on a m60b30 and still use the m60 5 speed transmission and clutch?
    WTB:m60b40 in PNW
    Zachary Ripley
    85 318i M50B25tu.
    92 525it 5 speed.
    80 244gl (m60 prepping).
  • wspellmann
    • Sep 2016
    • 110
    Originally posted by FireFight
    Hey, my question is will a flywheel and clutch kit from a s62 (e39 m5) work with a M60b40 and a 5 speed transmission from a e34 530i?
    I found a good used set that if it does work it will save a bunch of money on the project
    Thanks!
    I wouldn't use a used clutch. I got a LUK clutch kit for under $200 through rockauto.com.
    Unless you can get this for super cheap it isn't worth it IMO
    Sent from my Nexus 6P using Tapatalk
    My current E30 M62B44 swap
    • FireFight
      • Mar 2012
      • 1367
      yeah I was planning on swapping that out but keeping it s62 if i went this route
      WTB:m60b40 in PNW
      Zachary Ripley
      85 318i M50B25tu.
      92 525it 5 speed.
