740i oil filter bracket
  • flyboyx
    • 8371
    i had posted a reference to this in herpdederp's thread and have gotten a few pm's for photos. i figured the easiest way for members to search for this in the future would be to post a separate thread.
    here are the pics.
    this one is the side that mounts to the body.
    filter mount side
    one more for good measure
    i found this part in a local junk yard. i don't remember which year it came from but the model was a 740i. well, now that i think about it, there is a very slim chance it came from a 540i? perhaps one of you can research it on realoem and come up with a part number?
    also, i see no reason the oil filter housing needs to be mounted in the vertical position. my car will have a/c when i am finished as well as abs brakes. i am thinking about mounting it horizontally under the inner fender on the driver's side. this position will make it easier to drain used oil from it anyway.
    Gigitty Gigitty!!!!
  • Jean
    • 18228
    Awesome , thanks buddy !
    Haven't found it yet, closes is #1 and #2 but doesn't look like yours .
    http://www.realoem.com/bmw/enUS/show...diagId=41_2082
    I've been looking in E38 740i cars as well....maybe someone else can confirm what cars had this bracket?
    • JoeMadoo
      • 936
      Number 21 here. Seems to have only come on E39's.
      '86 E30
      '05 E53 X5
      '72 Firebird
      '10 Prius
      '03 Tundra
      • Jean
        • 18228
        Sweet!
        • dasmanschaft012
          • Apr 2014
          • 642
          get ready for messy oil changes :D
          We're in deep now boys
          1988 325i SETA - Daily driver
          1988 340iL - Track car
          My M60 V8 swap thread here
          [oo==OO==oo]
          • flyboyx
            • 8371
            would it be any worse than changing the oil on an m20? if you can get a pan under it before the lid comes off, i would think it would just drain into that.
            Gigitty Gigitty!!!!
            • Jean
              • 18228
              Yeah, shouldn't be an issue. I am looking at it and if you tilt the housing straight up, then you are adding extra stress/kink on the oil lines right above the frame rail :/
